Results 1 to 13 of 13
Thread: DV vac line?
    Registered Member Two Rings
    Nov 17 2007
    seattle, wa
    DV vac line?
    I tore the vac line that's right off the DV. You know, the thin threaded one that runs back up to the engine; not the connection to the turbo outlet hose. I'm just wondering if anybody knows where this vac line goes, or if there's someone on here who has diagrams of where each vac line goes on the 1.8T ATW engine
    Actually, on second thought, I think it's the one that runs back up to the turbo inlet hose. Anybody have a diagram for it, so I know exactly which twists and turns I need to take to reach my destination, when I put a new vac line in? Word on the street is that this particular one is a bitch to get back in
    2000 A4 1.8TQ Tip
    Veteran Member Three Rings Brooksthepro's Avatar
    Apr 29 2005
    2001 Audi a4, loud ass gocart!
    Santa Barbara, Ca
    Re: DV vac line?
    pretty sure thats the one wraps around the engine to under the intake manifold......but i could be thinking of a different one..........i would emagine that one would be a pretty big PITA
    edit: quick search turned up this:
    GIAC FXK04/Gen380cc/TTMAF/FMIC/custom magnaflow/710n/Labree HFC/034 Highflow Exhaust Mani/17"Team Dynamics ProRace1/CAI/race springs/Rs4 Grille/VDO vent boost gauge/SS brake lines/x-drilled rotors/12in Infinity /600w Infinity amp
    SANTA BARBARA LOCALS!! SBEUROCLUB
    Veteran Member Four Rings audisnapr's Avatar
    Jun 06 2004
    1993 Ford E250 Sportsmobile, 1990 Corrado w/ VR6 swap track car, 2011 Mazda3 S Sport 5dr
    Re: DV vac line?
    correct, it goes to the underside of the intake mani
    Jun 06 2004
    Re: DV vac line?
    Dec 01 2006
    Santa Cruz, CA
    Re: DV vac line?
    You should get rid of the N249 valve that controls the dv and connect it directly to the intake manifold.
    Nov 17 2007
    seattle, wa
    Re: DV vac line?
    Quote Originally Posted by dab_master View Post
    Interesting. Is there a DIY around here somewhere for that? I thought it was the N75 that controlled how much boost the DV held...
    2000 A4 1.8TQ Tip
    Jun 06 2004
    Re: DV vac line?
    n75 controls the wastegate actuator - #22 connected to #21
    Apr 29 2005
    Santa Barbara, Ca
    Re: DV vac line?
    n75 controls the wastegate i think
    edit:
    damn it snapr, u beat me! lol
    Nov 17 2007
    seattle, wa
    Re: DV vac line?
    Oh, gotcha. How would I go about bypassing the n249; refitting the DV bung onto the intake manifold in place of the current one there?
    2000 A4 1.8TQ Tip
    Apr 29 2005
    Santa Barbara, Ca
    Re: DV vac line?
    Quote Originally Posted by Leifer View Post
    you would plug it in directly on the nipple on the front of the intake manifold.
    but what would this accomplish?
    Nov 17 2007
    seattle, wa
    Re: DV vac line?
    It would feed the DV line straight into the intake manifold, thus bypassing the need for the n249?
    Sorry, I have no idea beyond that.
    2000 A4 1.8TQ Tip
    Dec 01 2006
    Santa Cruz, CA
    Re: DV vac line?
    if you do that, you need to put a resistor in the N249 plug to make the ecu think it's still there or you will get a cel
    Nov 17 2007
    seattle, wa
    Re: DV vac line?
    It's really that simple? Damn, I might have to do that.
    2000 A4 1.8TQ Tip
