Page 1 of 4 123 ... LastLast
Results 1 to 40 of 133
    Veteran Member Four Rings KompMan420's Avatar
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    Popped my drag strip cherry today...
    Got there a little late so I only ended up getting 2 runs. First one pretty much sucked, but I didn't break anything so I was happy. Second one I felt much more comfortable and had a good improvement and still didn't break anything.
    My concern is that my times seem pretty high for my mods. I'm making full boost, but I haven't tested for leaks.
    First run:
    .838 - R/T
    2.039 - 60'
    5.827 - 330'
    8.968 - 1/8
    79.54 - 1/8 mph
    11.593 - 1000'
    13.832 - 1/4
    100.48 mph
    Second run:
    .642 - R/T
    1.895 - 60'
    5.556 - 330'
    8.574 - 1/8
    82.74 - 1/8 mph
    11.123 - 1000'
    13.314 - 1/4
    102.11 mph
    Mods are in my sig, but I'm wonding if the stock IC's played a part or if I just need to learn how to drive?? Track conditions were pretty mild. 76 degrees, sea level, overcast.
    All in all, I'm happy nothing broke, but I was expecting 12's
    SOLD - 2001.5 Audi S4 Twin Turbo ~ 450hp
    Mods - AWE/GIAC Stage 3 | AWE Intercoolers | STaSIS Coilovers | RS4 Clutch | 3" Borla Cat-Back | ASP DTS | JHM Solid Axles | "Piggie" downpipes | Neuspeed SS | AWE Pedals | IceLink for iPod | 710n DVs | M3 Spoiler | LM Reps 18x8.5 Satin Black w/red Time Attack
    www.NJSRealty.com
    Dec 01 2007
    Markham, Ontario
    Re: Popped my drag strip cherry today...
    yeah it does seem high... for a 420hp S4
    run a vag to check for errors i guess
    Active Member Four Rings
    Jul 17 2004
    Yikes, you sure you have K04s? heh
    Alex
    2001.5 Nogaro Blue S4, 6-Speed, ARD 2.7T 68mm HTA GT2868 Kit
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Yikes is right, sorry! I can almost pull the same time with just a chip. I'd start logging.
    Also, any CELs?
    --Adam
    Have questions? E-mail me.
    Active Member Four Rings FrimmelNoJerz's Avatar
    Sep 21 2006
    Norjerz
    what track?
    SBSC
    I also like to live dangerously.
    Veteran Member Three Rings SilverSurferS4's Avatar
    Jun 11 2007
    Were you launching the car?
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    Only code I've got is for an AC pressure switch. Temps were mild, probably 75-80 degrees. I didn't check, but weather.com said a high of 76 today. I'm thinking I might have a small boost leak, but I am spiking at around 21psi. Yes, I'm sure I have K04's...
    This was down at Bradenton Motorsport. I was launching around 2500-3000rpm's, but honestly, I didn't look. Being a noob at the track I was just focused on the tree and NOT hitting the wall.
    www.NJSRealty.com
    Jul 17 2004
    You could break the 12's by lowering your 60' but that is still way off in both trap speed and ET for a stage 3.
    Alex
    Sep 14 2006
    14 GLI
    60 foot wasn't bad for a 1st trip to the track. As Alex noted, dropping the 60ft (ie - better launch) still wouldn't be enough to make sense.
    --Adam
    Veteran Member Four Rings Boris's Avatar
    Dec 20 2005
    District 7
    somethings not right. 100 mph trap? the b6/7 s4s are trapping higher than that stock..
    Somethings not right..
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    I agree, but what's not right? That's the question.
    www.NJSRealty.com
    Sep 14 2006
    14 GLI
    Are you on the stock fueling? What kind of tune do you have?
    --Adam
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    Out of the box AWE stage 3 pump gas. The only thing I don't have from that kit is the Intercoolers and headers. Those are both stock.
    EDIT - Oh yea, I did have 3/4 of a tank at the time with full interior, etc.
    www.NJSRealty.com
    Senior Member Three Rings YBLEGL's Avatar
    Sep 22 2006
    2001.5 AUDI S4
    BOSTON
    I ran a few mid to high 12's a while back at stage 2+ on stock intercoolers no MBC you should easily see low low 12's or even 11's on that setup.
    MAINTENCE AND STAGE 3 INSTALLS DONE, PM ME, MASS/ RI LINE AREA
    2001.5 S4 SILVER 6 SPEED BUILT BLOCK AND SINGLE TURBO KIT WITH PTE 6262.
    Account Terminated Four Rings
    Mar 14 2007
    michigan
    Get some ics and turn the boost up, not to start anything but the cars not making anywhere near 420hp thats the problem. Revhard went 13.1 at 104mph stage 1 full weight on 19ss with a slipping clutch on garbage tires in his old car and his car was making less then 325hp.. He had a chip and catback thats it
    Sep 21 2006
    Norjerz
    want my rs4 intercoolers and apr hoses? for a price of course.
    SBSC
    Sep 14 2006
    14 GLI
    Quote Originally Posted by generationjdm View Post
    Get some ics and turn the boost up, not to start anything but the cars not making anywhere near 420hp at only 15 lbs thats the problem. Revhard went 13.1 at 104mph stage 1 full weight on 19ss with a slipping clutch on garbage tires in his old car and his car was making less then 325hp.. He had a chip and catback thats it
    His rims weigh 15lbs, I think. He noted he was spiking to 21psi.
    Also, KompMan, what are you holding boost at?
    --Adam
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    wow dude something is definitely wrong. wtf. are you a tip or something lol?
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Active Member Three Rings panix73's Avatar
    Mar 17 2006
    Battleship Kruzer
    Long Island, NY
    The ambient temps are certainly playing a part in your high times, espeically as you get further down the track, pushing the car harder. Although you are still on stock IC's, you should be trapping much higher on the 1/8 and 1/4 mi. Your second run was obviously better and with a 1.895, it wasn't a terrible launch.
    What were your shift points? Thats the only other thing I could think of that could be causing a slower trap, besides the ones discussed..
    Innovate.
    Jul 17 2004
    I don't think the temperature has much to do with it...
    Here is a run with my Stage 2 on 93 octane, stock downpipes, all cats and stock IC's... Run was in 75 degree weather after hotlapping.
    1.753 - 60'
    5.357 - 330'
    8.312 - 1/8
    84.14 - 1/8 mph
    10.849 - 1000'
    12.974 - 1/4
    106.34 mph
    vs. his stage 3 in the same temp...
    1.895 - 60'
    5.556 - 330'
    8.574 - 1/8
    82.74 - 1/8 mph
    11.123 - 1000'
    13.314 - 1/4
    102.11 mph
    Alex
    Sep 21 2006
    Norjerz
    im sorry...i had to.
    it was working.
    SBSC
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    Quote Originally Posted by jungb5s4 View Post
    HAHA
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Active Member Four Rings ///M3 TO S4's Avatar
    Feb 09 2007
    Charlotte, NC
    this was a 1/2 mile, right? Please, tell me it was.....
    Your car does NOT have 420hp......not anywhere close, id give you 300hp, tops. You're running what a STOCK B5 S4 runs, basically.....You need to check a LOT of things, I have an awe stage 3 car on pump too, and it's deff. a low 12 sec car. What rpm are you shifting at in each gear?
    Learn MANTH America!
    Stage 3....blah...blah...blah... : Sold
    Now: E36 M3 TURBO (GT35R)
    Sep 14 2006
    14 GLI
    Quote Originally Posted by FrimmelNoJerz View Post
    Sep 14 2006
    14 GLI
    Quote Originally Posted by ///M3 TO S4 View Post
    This post really isn't necessary.
    --Adam
    Veteran Member Four Rings JMTx86's Avatar
    Oct 03 2005
    Sounds like driver error to me. More boost, ebay FMIC = 12 even with bad driving. And what clutch are you running?
    00 b5 s4 Single turbo
    1969 Chevy Nova 396 (Full resto, completed in 2016)
    1969 Chevy Camaro 454 (built 454/th400, body is a work in progress)
    11 Chevy z71 5.3 shop truck (Vortech V2 build in progress)
    Feb 09 2007
    Charlotte, NC
    I'm sorry Adam......:( I wasn't trying to be mean...just honest, and giving him something to compare to.
    Sep 14 2006
    14 GLI
    Yes, I know. But, you know it's a 1/4 mile track and you didn't present any #'s to compare to. Just saying
    No worries.
    --Adam
    Veteran Member Four Rings AB18's Avatar
    Dec 17 2004
    US
    ^ Since when does basically stock S4 run 13.30s in the 1/4?. I can drive, and i had to drive mine into the ground to see 13.90s basically stock. My guess is your not shifting fast enough. Heres one of my old slips..
    60ft- 1.850
    330ft-5.6
    660ft-8.8
    MPH 77.34
    1000-11.6
    1/4-13.93
    Basically stock,unchipped.
    2001 S4 6sp...has a few goodies...and JHM shifted
    Tons of parts for sale..
    GIAC A box ECU for sale-350shipped.
    http://www.audizine.com/forum/showthread.php?t=170072
    Feb 09 2007
    Charlotte, NC
    Quote Originally Posted by AB18 View Post
    60ft- 1.850
    330ft-5.6
    660ft-8.8
    MPH 77.34
    1000-11.6
    1/4-13.93
    Did you happen to look at his first run.....Looks pretty damn close to me....
    First run:
    .838 - R/T
    2.039 - 60'
    5.827 - 330'
    8.968 - 1/8
    79.54 - 1/8 mph
    11.593 - 1000'
    13.832 - 1/4
    100.48 mph
    Feb 17 2008
    Ottawa Ont.
    I agree that you are not making power.
    Id say the first thing to check is for boost leaks.
    Veteran Member Four Rings gotaudi's Avatar
    Jan 26 2006
    2001 A4 1.8T
    Socal
    he doesnt have to look very hard if he has a boost leak. it has to be huge
    BetaAlphaTau Member#22
    Mods:
    GTRS Elim+Unitronics+ATP high flow mani+Neuspeed TIP+Custom intake+Labree HFC+Apexi AVC-R+APR Exhaust+Precision FMIC+SB OFE Stage 4+034 street density motor mounts+Purems snub+S4 Front bumper+18" BBS RC rims+Neuspeed race springs+Bilstein shocks+Nuespeed sways=
    73 74 69 6c 6c 20 73 6c 6f 77 <--- Look it up
    Dec 17 2004
    US
    First run:
    .838 - R/T
    2.039 - 60'
    5.827 - 330'
    8.968 - 1/8
    79.54 - 1/8 mph
    11.593 - 1000'
    13.832 - 1/4
    100.48 mph
    Did you happen to look at his second? On his first run he had a 2.0 60ft, what do you expect? You can throw out that first run as far as im concerned. Also, if he is making the boost he says he is, he doesn't have a "huge" boost leak.
    Mar 14 2007
    michigan
    100mph is obtained on basically stock s4ss
    Dec 17 2004
    US
    Not very easy, i only trapped 97mph.
    Feb 09 2007
    Charlotte, NC
    You have to take in MANY, MANY different factors....elevation, temp, humidity, condition of stock car....you can't make a blatant assumption that a stock S4 is slower/faster than your car, that it's the standard. I hate to "bench race" but car and driver trapped 100mph and ran a 14.1 like 6 years back.
    Dec 11 2006
    Boston
    At the end of the day the OPS ride is clearly not performing up to par. So lets help this guy out.
    I think some logs would help.
    Stage 3+ RS6's
    Dec 17 2004
    US
    I agree, if the op could post up some 3rd gear pulls it would help alot.
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    Ya know, I expected some flaming and that really doesn't bother me since this was MY FIRST TIME AT THE TRACK, but it's painfully obvious there's something wrong. Thank you to those that are trying to help me track down the issue. I'll try to do some third gear logs, but what do you guys recommend I log? Just boost?
    Also, I usually hold at around 17-18psi boost according to my AWE gauge, but I'm pretty sure that thing is about a tick or so low like a lot of the others. I'm going to try getting some new DV's this week. I've had them for almost 50k miles and it's cheap enough to just replace them.
    I'm shifting at around 6500-6800rpm's. I've found from my street experiences that shifting any higher just kills my power since I am running stock IC's. I know I'm no pro driver, but I'm shifting pretty quickly. It's not like I'm driving Miss Daisy
    www.NJSRealty.com
    Mar 14 2007
    michigan
    Know one is flaming you, werr just saying theres an obvious problem..
