Results 1 to 28 of 28
    Nov 28 2007
    Acton, MA
    Question Knocking type sound at Idle
    Hey guys, first post here since I got my CPO '06 A4 28,000 miles- been browsing for a while though :) I did a search and couldn't find anything that pertained to the issue that I am having.
    Bought my car in November of '07 and had a few problems when I first purchased it, but I love the car and have been relatively problem free since the initial instances. First the coil-packs needed to be replaced 3 days after I picked it up. Got the car back, needed a new fuel pump a week later. And finally the wind shield started leaking above the rear view mirror... Luckily the dealership I purchased the car from is down the street from my house and has been very helpful with fixing the problems and giving me a loaner car free of charge.
    Fast forward a month - I started to hear a knocking type noise after the car has fully warmed up. When the engine is cold/fresh start it sounds perfectly, little noisy but I guess thats normal for our engines. When the engine is warm and has been driven for about 5 miles there you can hear a very audible knocking sound, almost sounding like a diesel, coming from the engine.
    I brought the car into the dealership to have them investigate, had the service manager come out and listen to the noise before I left so he knew what I was referring to, and he agreed there was a problem. Got a phone call 3 days later from the dealership stating that they heard the problem, but checked everything mechanical and everything was working fine. I was told not to worry about the noise.
    Now, one month later the noise is even more audible. Has anyone else experienced this kind of noise? It puzzles me because the noise is only audible after the car is fully warmed up and has been driven for a few miles. Any clue what the problem could be so I can take it back to them and get it fixed?
    ~Lyds
    C/N: Bought car in November, had a few problems nothing major. Now have a audible knocking type sound @ idle after warm up. Dealer says nothing mechanically wrong, but the noise is abnormal any advice ?
    Nov 12 2006
    2007 A4 2.0T
    GA
    Re: Knocking type sound at Idle
    Is it ticking sound? like Tick tick tick....?
    If it is, it's normal
    2007 A4 2.0T FWD 6MT Quartz Grey
    APR 93
    APR Snub
    RS4 Pedals
    Momo Shift Knob
    Servotronic Disabled
    Piloti Driving Shoes
    Nov 28 2007
    Acton, MA
    When I had the A4 loaner they gave me I did not notice the same noise. I know the injectors/fuel pump on this car is noisy, and it definitely does not sound like the ticking noise that they make.
    Veteran Member Three Rings Zebman's Avatar
    Dec 25 2007
    '06 A4, 08 R6s
    Morgantown/Hurricane, WV
    You are putting 91+ octane in it, correct?
    It could be a slew of problems, hopefully it is injector-related.
    2006 A4Q 6MT Arctic White - StageII++
    STaSIS SS Coilovers, EVOMS Intake, APR 93, OZ Ultraleggeras 17x8, APR Exhaust w/034 HFC, GSG Intake Pipe, AWE Front Mount, APR HPFP.
    2008 R6s
    : Racebike, don't feel like writing it all out.
    I don't get on Audizine anymore, so if you need me... sorry.
    Nov 28 2007
    Acton, MA
    Since i purchased it, I have never put anything under 93 in it.
    In Limbo Three Rings
    Jan 18 2008
    2006 A4 2.0T quattro mt
    central jersey
    why do are cars make the tick tick tick sound?
    Established Member Two Rings RisR32's Avatar
    Jan 15 2008
    Philadelphia
    is it a man. transmission.... could be the fly wheel... I had a similar issue on my .:R once I replaced it, no more ticking on idle.
    04' DBP R32 SOLD, 06' A-4 2.0t SOLD, 10' GTI SOLD, 11' A-4 2.0t Titanium Avant SOLD, 2012 TTRS SOLD, 17' S3 SOLD, 18' RS3, 19' Q8, 2021 RS6 Avant
    Nov 28 2007
    Acton, MA
    It is a manual transmission, but its not a ticking noise. What confuses me is that the noise is not there when the car is cold, just when fully warmed up.
    Veteran Member Four Rings SilverB7FL's Avatar
    Feb 19 2007
    Built Twin Turbo 350Z
    S. Orlando
    I was told it was the emissions purging. My car does the same thing except I get it up front near the engine and also in the back near the gas tank.
    Girls love Audi too.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    the ticking is normal, most people think it is the valve sticking usually happens because you don't use premium gas but its normal for audi whether you do or not, sounds like a diesel...
    Registered Member Four Rings 4-tified's Avatar
    Sep 18 2006
    A4 2.0T Quattro
    Chicago
    Quote Originally Posted by Lyds View Post
    If it were a throw-out bearing, you can make the noise come and go by simply pushing the clutch pedal in and out.
    If that's not it, then it's not the T-O bearing.
    Our FSI engines do sometimes sound a bit like a diesel.
    Granted, it's not the heavy knock sound of diesel fuel detonating, but the FSI does have this low "knock" type sound.
    This has been talked about by car writers and owners even since the FSI came to market. I don't know if earlier engines tend to have a more pronounced "knock" sound than newer FSI engines, but it seems to be pretty normal.
    The sound is caused by the direct injected fuel and the relatively high compression ratio for a turbo charged engine.
    My 06 2.0T, manual has that odd low "rumble" or "knock", but it's not like an actual metallic knock sound per se, just an odd low tone.
    When the engine is cold the rpm is higher and overall engine noise volume is greater, thus you don't hear the lower pitched tones, and due to higher rpm, there simply may be less actual "knock" sound generated.
    As you drive and engine speed increases you notice the overall engine tone change, and no knock sounds. I do find that there is a kinda cool low pitched "growl" as the engine accels past 4k rpm. I like it.
    From everything I've read and heard about the FSI, I don't think it's a problem. If what you hear is a VERY audible metallic "knocking" sound, then the Audi dealer needs to look deeper into the issue. If it's a general low volume sound, it's probably normal.
    The loaner you got, it to is a manual? If not, then it's a different comparison, although you could put an auto in "park" and then the engine will idle nearly the same.
    Plus, as I said, perhaps the newer FSI engines are a bit quieter.
    I've driven a few A3 2.0's auto and manual, and some automatic A4 2.0's.
    Some had the more pronounced low rpm "knock" sound of like my 2.0, some less, and a couple that sounded a bit louder.
    When was the last time the engine had an oil and filter change?
    Also, the weather is quite a bit colder now. Has the sound become different in the winter compared to when it was warmer?
    The distinctly different "ticking" sounds are not the low rpm "knock" sound.
    Ticking sounds in the engine are usually the fuel injectors and/or the self adjusting hydraulic valves.
    Injectors have the tick, which is a normal part of their function, some are louder than others.
    The valve lash adjusters can tick due to not enough oil pressure built up to fully set the valve lash.
    They can tick due to varnish/gunk build up inside the oil hole, thus the adjusters can't adjust fully.
    Sometime tick can be heard and described by some as a "knocking" sound.
    This sound can occur when the engine is cold and oil pressure had not built up in the adjuster yet and thus the valve lash is a bit off.
    As the engine warms the oil pressure in the adjuster rises and things quite down.
    If the noise starts when the engine is warm, then it could be that the adjusters are dirty/varnished, and that might be due to too long of an oil drain interval. Since you bought it used, it would be good to see the maintenance record.
    Also, you can get a ticking problem that pops up when the engine is warm, but not when it's cold, when a too light weight oil is used for the environment.
    When cold the oil has a certain viscosity that can pressurize the adjusters normally. But, when the oil heats up the viscosity can decrease and the oil becomes too thin to keep the oil pressure up in the adjusters. If the pressure drops in the adjusters then the valve lash can be off and a ticking noise can happen.
    So, too thick or too thin oil can cause the ticking noise too.
    Try an oil change with a good FULLY synthetic oil in the correct viscosity range for your atmospheric conditions and see if that calms things down.
    Jun 05 2007
    Phillips Ranch, CA
    ^ agree. FSI tend to sound like diesel. So it may be normal,
    Nov 28 2007
    Acton, MA
    The noise is there regardless of whether the clutch is depressed or not, so i dont believe its the T-O Bearing.
    The actual volume of the sound is quite audible. I guess the best way to describe the volume is that sitting inside the car, if the radio is under volume #6 I can hear the sound still. As to the sound, it sounds metallic, definitely not a ticking type sound.
    The loaner i received was also a manual with a 2.0T engine.
    And the oil and filter was last changed about 2,000 miles ago.
    Jun 05 2007
    Phillips Ranch, CA
    take it in if u must? im sure they will have a better idea if u dont fels its normal
    Nov 28 2007
    Acton, MA
    Quote Originally Posted by acidrome View Post
    Therein lies the problem. I took it to the dealer, they said the sound was abnormal, but failed to diagnose the problem after 3 days of having the car. They said everything is mechanically sound. Guess ill just have to take it to a different dealership and see if I have any luck there.
    Jun 05 2007
    Phillips Ranch, CA
    wow thats wierd, but ya i guess take to another dealer now if they say they same then i guess ur goin to have to take their advise
    Senior Member Two Rings joshd2012's Avatar
    Nov 20 2007
    2006 Audi A4 2.0T Quattro 6MT
    Arlington, VA
    Quote Originally Posted by 4-tified View Post
    It definitely freaked me out the first time I drove an Audi. I couldn't believe how loud the engine was compared to my last four banger. I found out it was normal, but it still throws me for a second every time I put down the window and don't have the sound muffled by my firewall.
    That said, I did come across a used A4 that had a metallic sound at idle, but it was constant. The car was noticeable louder than other Audis, even side-by-side you could hear the difference. It sounded like something was hitting every time the engine cycled. I mentioned this to the dealership, and they said they had gotten that same comment a few times about that car. They didn't know why, though.
    2006 Audi A4 quattro 2.0T 6MT
    Engine:
    Podi Boost Gauge / Audi Rev 'D' DV / Carbonio CAI / Blinktek Heat Shield / 034 Turbo Inlet Hose
    Exhaust: Stasis Exhaust / LaBree HFC
    Suspension: Vogtland CO / RS4 Rear Sway Bar
    Wheels: 18" Audi USP (Powdercoated Black) / H&R Spacers / Goodyear Eagle F1 A/S
    Exterior: Audi Euro Xenon Retro / Deval Rear Spoiler / Audi Filler Plate / Painted Sidemarkers
    Future: K04
    Nov 28 2007
    Acton, MA
    Quote Originally Posted by joshd2012 View Post
    That sounds exactly like I am talking about, except the sound was not there until after I purchased the car.
    I'm just getting antsy because I want to start modding, but I want to make sure everything is sound before I start doing anything.
    Veteran Member Four Rings TSlice's Avatar
    May 18 2007
    Houston
    Just make sure you are on record with your dealer as reporting the problem and having them not be able to diagnose it so you won't have any problems as far as warranty goes if something were to go wrong.
    Feb 19 2007
    S. Orlando
    I have a 05.5 and I had to get an 08 loaner and that A4 was def. alot quieter engine wise then mine, it also didn't have the horrible vibration at idle like mine does
    Veteran Member Four Rings trueno429's Avatar
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    i noticed that it was EXTREMELY loud tonight when i got done driving my car during idle...i noticed the sound too when i got the car used a few months back and i also noticed that it only makes the sound when ive been driving for a while..tonight i drove for 2 straight hours and it made alot of noise..maybe our engines just needs to cool down
    Registered Member Two Rings
    Oct 23 2007
    05.5 B7 A4 2.0T Q
    Dallas, Texas
    Does this thumping/knocking noise sound like its coming from the front or back of the car. Does it sound rythematic or is it random?
    Mar 14 2008
    Atlanta
    LYDS, I'm in the same boat. Purchased a CPO 06' 2.0T in January 08'. Just got back from my second visit to the dealer for the engine ticking. First time they found nothing. Second time they replaced the fuel pump. No change to the very loud ticking that stands out at idle. My 08' loaner sounded fine...
    Senior Member Two Rings cecaa's Avatar
    Feb 13 2008
    2007 A4 2.oT MT S-line Ti
    Vancouver BC
    4-tified had very impressive answer! thanks
    Veteran Member Three Rings tribe's Avatar
    Feb 15 2008
    lotsa tools
    Vienna, VA
    That could be a rod knocking. You can buy a cheap stethoscope at a CVS and listen to your engine and localize the exact place of the knocking.
    Since the coils and the fuel pump went south shortly after you got it, you can presume that the car has been used hard.
    Good Luck
    '12 Phantom Black S4 P+ S-Tronic- Navi - 3M Clear Bra - KW Springs - REVO Stage I - AWE S-Flo Intake - Hotchkis sways (still in the box)
    Veteran Member Three Rings Unleaded20T's Avatar
    Mar 27 2008
    Ducati Streetfighter V4S
    Allen, TX
    tic tic noise its normal, but a knocking noise could be a lot of things, most common is bad valve/s.
    [Current] 22' S6 | Daytona Gray | BO | Prestige
    [Sold] 21' S5 SB | Glacier White | BO | Prestige
    [Sold] 19' SQ5 | Ibis White | Prestige
    [Sold] 2016 A6 | Moonlight Blue | 3.0T P+
    [Sold] 2011 A6 | Black | Prestige
    "If everything seems to be under control, you are not going fast enough." - M.A.
    Veteran Member Three Rings gyroscope's Avatar
    Mar 19 2007
    06 A4 S-Line Quattro, 98 K1200RS, 21 GTI SE DSG
    Queens, NY/Poconos, PA
    The ticking noise is normal for these engines. Mine does the exact same thing. Sounds like my fathers TDI. It's the FSI injectors snapping the fuel into the engine.
    Registered Member Two Rings OceanBlueB7's Avatar
    Oct 15 2007
    Ocean Blue Pearl '06 A4 2.0TQT
    Boise, Idaho
    Exhaust leak perhaps?
