Page 3 of 5 FirstFirst 12345 LastLast
Results 81 to 120 of 172
  1. #81
    Veteran Member Four Rings 1RAudiSQ5's Avatar
    Mar 08 2007
    Ashburn Va
    Re: a Bit longer than 5 minute Fogs w JUST Parking/City Lights
    Quote Originally Posted by tatarin View Post
    i did my fog mod today... works great... thanks for the instructions on how to take that switch out!!!
    also i noticed many people are still confused on how to set the car to (rest of the world via vag-com)
    so what you do it
    click on
    - Select Module
    click on
    -option - 09 cent. elect.
    click on
    -coding ( in software coding box) change the last digit to 1
    click on
    -do it
    you are done
    I have to do this tomorrow
    2019 Audi SQ5 Premium +: CETE module // Vorsteiner VFF-107 22x10.5 // AWE Cold Front // CTS Intake // CTS Turbo Inlet // 034 Trans Insert // AWE Touring Exhaust // 034 Swaybars
    2021 Audi SQ7 Prestige : 034 Lowering Links //
    AKA WantaA4
  2. #82
    Veteran Member Four Rings PSYC0TIC ONE's Avatar
    Oct 19 2005
    2022 Mazda CX-5, 2013 HD FatBoy Lo
    Virginia
    Quote Originally Posted by Audi0s View Post
    SO do you need to actually power the circuit? Or can you just change the coding and the fogs will be powered? No one has answered yet....
    what do you mean power the circuit?
    unless you've already "modded" the headlight switch, just coding won't do anything for you... you'll need to do this mod or Eddie Man's in order to get the fogs to come on without headlights
    -Cliff
    Current:
    B9.5 //S4-Prstg-Turbo Blue on Gray-30% Tint
    B8 //S4-Prstg-6MT-Ibis on Blk-Sprt Diff-35% Tint-H&R OE Sprngs-AWE CatBack
    B6 //S4 Nogy on Nogy-19" OZ SLs-FI NonRes CatBack-Hardwired V1 w/ LIS4 Display & LaserMask-30% Tint-RS6 Pedals-BiXenon ECodes
    B5 //S4 Cactus on Black-Sport Pckg-18" Flik Justices-JHM Shrt Thrw-APR Stg1
  3. #83
    Established Member Two Rings 2LOW4NYC's Avatar
    Apr 05 2009
    Quote Originally Posted by whartung View Post
    damn i didnt realize that the ebay cables didnt work. i'm not going to shell out that kind of money for the vag-com then. Anyone in the upstate NY or even NYC area have one they can help me with sometime?
    i have a vag-com in NYC
  4. #84
    Registered Member One Ring un pimped audi's Avatar
    Feb 11 2009
    Florida
    Did this a while back... its great. Wanted to know if anyones posted or knows a way to get city lights without buying ecodes.
  5. #85
    Established Member Two Rings B7Lee's Avatar
    Jun 01 2008
    B8.5 S4 - previously B7 S4
    Boston, MA
    Cheers to you PSYC0TIC ONE. Did this according to your DIY photos. Works flawlessly.
    05.5 Quartz Gray S4- MaD StUfF yoooO.
  6. #86
    Senior Member Two Rings Dirty(30)v's Avatar
    Nov 10 2009
    03 A4 3.0L
    North NJ
    awesomme write up man good stuff nnow i all i gotta do is find a someone with a VAG-Com cable
    Red ultra suede Trim
    clear corner/stealth bulb/ yellow fogs
    DONZ 19''/vmaxx coils/15mm spacer*/ rs4 swaybar/ custom intake
    votex rear*/ usp front*/ DTH side skirts/ trunk lip/ badgeless grill
    I have a bunch of stereo stuff for sale wanna get ride of it asap
    http://forums.vwvortex.com/showthrea...vd-cd-mp3cd%29
  7. #87
    Veteran Member Four Rings whartung's Avatar
    Feb 01 2007
    I did this mod about 6 months ago, and today, my fogs are having a weird issue, which I assume is because the tape is shifting or the copper cable now has a bad connection. Without any bulb out warnings, and with a brand new set of fogs, my fogs will turn on and off on their own when i have them turned on. The weird thing, is that I get no dash warnings, and that the green fog light indicator located on the headlight selector will turn off along with the fogs, which leads me to think the problem is somewhere in the switch itself. I'll look into it when I get back to my car from winter break, but I figured it was worth a heads up, as I think it is a side effect of this mod.
    Sold: 2005.5 Sprint Blue Pearl Audi S4 Sedan 6MT
    Corsa w/ 12" Resonators - Vogt GT's - Trexturk Catless Downpipes - JHM Tuned - JHM SS - JHM Intake Spacers - JHM/Apikol Rear Differential Mount - JHM LWCP - K&N - RS4 Sway - Blackout Grille - ClearCornered and Blackedout Headlights - Xeonmatch - ECS Snub
  8. #88
    Registered Member Two Rings
    Feb 09 2008
    nyc
    Quote Originally Posted by nycmalu View Post
    The way the switch is set up, the fog lights only get power when the headlights come on. By splicing the fog wire into the main wire, you're fooling the system into allowing fogs to come on any time the switch can be pulled out (which doesn't include the auto setting unfortunately). However, that feature only works when you recode the lighting system to RTW. The Canadian setting is using fogs as DRLs. Since you don't need DRLs AND regular lights, they automatically disable anytime your regular lights come on, UNLESS you pull out the switch, so again, no AUTO setting.
    P.S. - Props go to FatAuto for the initial mod. Eddie Man brought it to our boards (I think)...
    For someone that wants to use the Canadian setting with fogs as DRLs, will just changing the VAG COM setting work? (I have an '05 B6 with no auto setting on my light switch) Thanks!
  9. #89
    Senior Member Two Rings greddy15's Avatar
    May 17 2008
    2007 a4, 2006 s4
    south florida
    is there a way to get it so that the just the fogs come on without the city lights?
  10. #90
    Nov 13 2009
    08 Triumph Daytona 675
    modesto California
    Quote Originally Posted by 1.8cab View Post
    I have an 07 B7 with no auto setting and just vagged it to Canadian with DRL and it works.
  11. #91
    Oct 19 2005
    Virginia
    just curious if you were able to diagnose the problem of your flickering lights?
    its been 2+ years and i still don't have any issues with mine...
    -Cliff
    Current:
  12. #92
    Jul 21 2008
    1997 Porsche 993TT, 2004 Sportsmobile, 1989 Mercedes 560SL, 2018 Macan GTS, 1984 BMW K100 Cafe Racer
    VAg'd mine to RoTW and it worked!
    2021 RS6 - Glacier White
    Also in the Garage - 1997 Porsche 911 993 Twin Turbo "Minty", 1984 BMW K100 cafe racer, 2018 Q7 Glacier White, 2004 Ford e350 Sportsmobile Camper Van/overland vehicle, 1989 Mercedes SL560
    Gone but not forgotten - 2018 Macan GTS Sapphire Blue Metallic "Babe the Blue Ox", 2016 S6 Nardo Grey "Sasha", 1995 Ferrari F355 "White Horse" 2013 RS5 Suzuka Gray Metallic "Suzy", 2005 B6 S4 Arctic White "Ghost"
  13. #93
    Veteran Member Three Rings felondnb's Avatar
    Jan 12 2008
    London, UK
    Just done this mod - quite fiddly wrapping the wire round the pins but only took a few mins to do.
    Cheers to the OP for the photos of which pins to do.
    Phantom Black Audi A4 2.0T FSi Quattro S-Line Special Edition
  14. #94
    Feb 01 2007
    Quote Originally Posted by PSYC0TIC ONE View Post
    nah i haven't bothered troubleshooting it yet. I need to though. Its still doing it. More often when the car and headlights have been on for a while
  15. #95
    Established Member Two Rings ProPain203's Avatar
    Jun 07 2009
    "Tha 203" CT
    chrislane is that newhaven (where ur picture was taken)
    2006 Saab 93 Aero 2.8t 6MT
  16. #96
    Veteran Member Four Rings jmw241's Avatar
    Feb 23 2009
    Cranston RI
    Awesome thread, I just found some old soder/tape and some small watch size tools from my grandpas old toolbox. (he passed away 10 years ago) This reminds me of him so much, simply amazing, gotta love this kinda thing.
    -Justin
    Current Cars: 07 Sprint Blue RS4 Cab,
    Old Cars: | EURODYNE Maestro | GTX-3071| B6 A4, Brilliant Black b6 S4, Phantom Black B7 A4
    07 Sprint Blue DTM S4, 12 Candy White Golf TDI
  17. #97
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    so i bought and used 24-gauge bus wire. would this make a difference since it is not copper? it does say tinned-copper which i figured would work for this kind of thing. if not then i know why mine is not working. weird thing is that i covered the pin and used the wire like the DIY states and my fog lights work the exact same as they did before.... can anyone shed some light on this? (and yes, i did already change the code to RTW)
  18. #98
    Veteran Member Four Rings irulea2's Avatar
    Feb 10 2010
    B7 2008 daytona gray RS4, d3 2007 daytona gray S8
    Phoenix, AZ
    Looks like I found my next mod!! Good write up
  19. #99
    Apr 07 2010
    mtl
    i have a b7 3.2L with bi-xenon and live in Canada.
    I want only fogs and corners as drls.
    How can i achieve that?
    thanks
  20. #100
    Established Member Two Rings LTizzil's Avatar
    May 07 2010
    B8.5 S4/K6 GSX-R1000
    ND
    OK, can anybody link an ebay seller with a Vag cable that will work with the B6 S4? Also, can programming be done with a Macbook?
    B8.5 S4
    034 Stage 2+
    Vorsteiner V-FF 103 19x9.5
  21. #101
    Apr 18 2008
    Jacksonville, FL
    Quote Originally Posted by LTizzil View Post
    thought all VAG cables worked...
    if you have a mac, you'll need to either use Boot Camp and set up a Windows install or use Parallels (or another virtual machine app) to use a virtualized Windows. I've done both.
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
  22. #102
    Apr 11 2010
    Norton, MA
    Did this on my girl's S4 Cabby just now. Worked perfectly! Car looks mean!
    THANK YOU!!!!
  23. #103
    Established Member Two Rings R8ted R's Avatar
    Jun 09 2010
    06 Audi A4, 05 Yamaha Zuma
    San Francisco, CA
    I tried removing the switch for 10 minutes but no luck! What am I doing wrong!? I started with switch at AUTO, turning CCW towards O and it clicks in twice. Then turned CW (while holding switch in) till it stops between 0 and AUTO and tried to pull it out but it just wont budge!! I also tried just pushing it in till it clicks at the O position and turning towards AUTO and pull out but it don't want to come out either. If i pull any harder.. something might break... Is it suppose to be this hard or am I doing something wrong?
    edit: nevermind, figured it out! Here's what I did: Take off the fuse box cover on the side, then while you're pulling up on the switch, gently push the connector in the back to help it out. Once the whole switch is out, remove the harness and the rest is just like how OP described.
  24. #104
    Established Member Two Rings joebleu's Avatar
    Dec 11 2009
    Los Angeles, CA
    Is it possible to run the fogs without the parking lights? I don't have citylight so that's not an issue.
    2003 Audi A4 1.8T Quattro
    APR Stage 1+ | Genesis 380cc Injectors | EuroCode FMIC | RS4 Sway Bar | Neuspeed SS | DV710N
  25. #105
    Nov 25 2009
    Lexington, KY/Orlando, FL
    We did this mod on my friends 2005 S4 and the wiring seems to be correct (everything is working) but when we tried to do the coding for RTW his ecu refused to accept it. So his fog lights are still only working with the headlights on. Any ideas or reasons this would be happening?
  26. #106
    Jun 05 2009
    Cool
  27. #107
    Active Member One Ring Badmamerjamma's Avatar
    Feb 28 2011
    Kentucky
    thank you for the explanation... its hard for me to answer questions while i'm on in Iraq but, this mod has been around for a while in quite a few variations...
    as you mentioned (and i in the original post) props to FatAuto and Eddie Man once again!
    What is the actually code for Rest OF WORLD? for S4/B6???? I thought it was 00011 but my ECU won't accept it.
  28. #108
    Established Member Two Rings avant1's Avatar
    Jun 20 2009
    97gtivr6T, 97jettavr6,95jettavr6,95cabrio
    New Jersey
    did this mod and it didnt seem to work the first time. it just changed my miles to km and my clock to 24hr time. Anyway i got someone else to vag it yesterday and just followed the values up top. it works now! the only thing different that i did was, instead of taping the pin. i just bent it flat. so no taping required. good stuff! thanks
  29. #109
    Established Member Two Rings RichieG's Avatar
    Apr 09 2011
    South Florida
    you have to love the internet.. i want to thank the Psycotic one, Eddie Man and FatAuto for this great post... the info on these sites are really priceless... i wanted to have my fogs work with my high beams.. and found this... i used a circuit board connector to jump the pins and shrink wrap with the glue inside to cover the #2pin.. less then 5 min and works great... once again thank you Psycotic one, as i did not want to cut anything... i am going to look in there in a few weeks and see if there is any melting of plastic.. there should not be, i believe that is all low voltage? once again thank you....... now if i can find someone here in south Florida to show me how to use this vag com!!!! that would be great.....
  30. #110
    Veteran Member Four Rings Mistro's Avatar
    Jun 19 2011
    Quote Originally Posted by ecb7 View Post
    thanks
    I'd like to know this too...
    From what I understand if you vagcom to the Canada Setting without bixenons (ie: locale setting of 4) you would have this, but can you still vagcom it to that when you have bixenons and not "hurt" anything?
    Right now, when I do this mod then vagcom to RTW, it keeps the city lights and fogs on, but no ambers, which makes sense since RTW would do that.
    But is there any way to have just the corner ambers and foglights when in the parking/citylight mode (with or without the city lights) or as DRLs?
  31. #111
    Oct 19 2005
    Virginia
    Quote Originally Posted by Mistro View Post
    wow, it's been forever since i've checked this thread. on another deployment, sorry fellas.
    i am not too familiar with the headlight hardware for the B7. i do know that, on the B6, if you get the euro e-codes your corners are not wired to be "parking lights", only blinkers and the "parking light" wiring is routed to the small bulb within the housing (city light).
    as far as using VAG-COM on your individual cars, the ross-tech website has FAQ's for all the cars, with links to all the little "hacks" most people perform (ie. setting the car to RTW - rest the world).
    i hope this LITTLE bit of info helps you guys!
    -Cliff
    Current:
  32. #112
    Jun 19 2011
    I'll just post this so that if anyone stumbles upon this thread in the future they'll some more resources to look at
    Thanks again to all you guys who figured this stuff out! (Psycotic one, Eddie Man, FatAuto etc...)
    Canadian B7 RS4 with bi-xenons (I'm assuming this applies to all bi-xenon B7s)
    Basically as I mentioned a few posts up, I wanted the corner orange lights and the fog lights on at the same time.
    I followed all of the steps PSYC0TIC ONE did except instead of using electrical tape, I just snipped the wire (Same result, just not as fiddly with the tape).
    After testing that it worked fine VAG-COMd to rest of the world, I tried setting it back to "US/Canada Bi-Xenon" (last digit as 3 instead of 1) and that did it.
    The strange thing is that it did not work earlier with it at setting 3. I'm not sure if you have to go to rtw and then back for it to work, or whether it was just some loose coupling with the connector since I also readjusted that in between as well. I guess if anyone's trying it and it's not working, you might as well try going to RTW and back... I'm pretty sure it was just a loose connection but who knows.
    So for reference, the lights now work as follows:
    off/O - DRL lights
    Auto - Auto... I don't really use this setting much
    Parking - Corner lights, and city lights
    Parking pulled - Corners, city lights, and fogs
    Main Beams - Xenons, corners
    Main Beams pulled - Xenons, corners, fogs
    The only thing bugging me now is the city lights... is there any way to disable these guys? I'm talking about the small dim lights in side of the DRL housing that aren't the DRLs
  33. #113
    Feb 08 2011
    14 Q7 SLine, 14 Allroad P+, BMW R1200RT, BMW F800GSA, Specialized S-Works Roubaix
    Camas, WA
    Nice recirculation of this thread. I did it on my previous b6 and just today had to look for it for my newer b7. Funny or maybe just easier thing was I didn't have to mess with the vag codes, maybe prior owner did this too but doubt it as the wiring harness was in tact and there was mods as outlined in this thread.
    US Version A4 3.2Q S-line
  34. #114
    Veteran Member Four Rings Coderedpl's Avatar
    Jul 27 2007
    Orange County, NY
    Only way I see that happening is resistors & modifying the wiring. I somehow managed to do this when I was installing my LED city light & DRL's and was messing with the wiring.
    Current: F80 M3 | 2018 Q7
    Past:2018 VW Golf R | 2014 S4 | 2016 Nardo Gray SQ5 | 2012 VW Golf R | 2006 Audi S4 | 2006 A4 2.0T |
  35. #115
    Senior Member Two Rings jayM's Avatar
    Jun 28 2007
    i always wondered why my fogs didn't come on when i pulled the switch in parking light mode. I just did this mod on a canadian b7, no vag needed. thanks
    2012 Mercedes-Benz C350 4matic Sedan
    2006 Audi A4 2.0t quattro - Sold
    Vancouver, Canada
  36. #116
    Feb 09 2010
    Jersey
    Just did this on my U.S. B7 and it worked without VAGing. Except the parking, fogs and cities come on. Rather just have just the parking and fogs come on, but I'm just happy I was able to get the fogs without the headlights.
    Past - 2008 Audi A4 2.0T Quattro 6MT S-Line Ti Ocean Blue Pearl
    Past - 2002 Audi A4 1.8T Quattro Tip Dolphin Grey
  37. #117
    Jul 19 2011
    Northern Minneapolis, MN
    This works awesome by the way. My B7 had no issues and it took all of 5 minutes to go grab my wire, strip it, cut it, wrap it, tape, and plug back in.
    Thanks!!
  38. #118
    Oct 19 2005
    Virginia
    damn, glad a 3 and a half year old post is still helping people!!! why i love this forum!
    -Cliff
    Current:
  39. #119
    Jul 19 2011
    for sure. idk why they dont come stock like this. zero downsides!
  40. #120
    Established Member Two Rings sleeper's Avatar
    Dec 23 2009
    salt lake city UT
    Brilliant! Thanks for the write up
