Results 1 to 6 of 6
    Veteran Member Four Rings chris@penskeaudi's Avatar
    Apr 28 2004
    Audi A4, Q7 s-line, B8 A4
    La Verne, Ca / PENSKE AUDI
    Question Homelink Question?
    what does it mean when you are trying to set the homelink up and after the lights flash three time to say it programed. then i get itside and it the button and the light starts flashing really fast and it doesnt work. and when you go to reprogram it when you push the button down the light flashes really fast then goes soild where it stays lit up for so long as you holding the button then it finally flashes slow to reprogram it but still wont work. what do i do
    Veteran Member Four Rings HyperM3's Avatar
    Mar 20 2004
    Lawrenceville, NJ
    How do you know it didnt work in the first place? I thought I had mine programmed wrong then I found out you need the key in the ignition to make it work. Plus, you need to hold it down for a couple seconds, then my garage door opened. You cant just quickly press it and expect it to work.
    21 S5 Coupe - RacingLine strut brace/034RearSwayBar/CTSTransMount/034 tune/VPS Res Delete/CTSIntake
    10 S4 (gone),13 S6 (gone),14 S6 (gone),14 S6 (gone),16 S6 (gone),17 A4 (gone),19 S4 (gone)
    20 BMW R1250RS
    ACNA Lifetime Member - 26690
    Respond to a post with an answer, they will keep asking questions. Teach them how to RTFM, they will learn to help others.
    Apr 28 2004
    i know you need the key in the ignition, i have programed it before on channel 2 but i put my gate on channel 3 and another grauge on channel 1 but for some reason it dosent work on channel 1
    EVOLUTIONRACEWERKS
    G.I.A.C fx k04 + TT225 injectors/k04-15
    Evolution Racewerks FMIC (black comp)-Evolution Racewerks Test Pipe-Evolution Racewerks Turbo Inlet Pipe
    Neuspeed Power Pulley-Neuspeed snub mount-Neuspeed Exhaust + misc mods
    Audi West Covina
    (AKA luvmshavd)
    Established Member Two Rings Kaliman's Avatar
    Jul 20 2004
    Cadillac Escalade
    Mission Viejo
    What type of device are you trying to program into Channel one? A garage door opener? Has it worked before? I have a garage door opener that changes its frequency automatically, I forget what it is called exactly. I had to teach the garage door opener to accept the signal from the homelink by pressing a button on the garage door opener and then pressing the homelink button, once it is programmed. Now it works.
    Veteran Member Four Rings giago's Avatar
    Feb 12 2004
    audi a4 1.8t 2002
    Mexico
    mine doesn't work.
    it's the second time it stops working.
    I have taken it 2 times to the dealer and they can't fix it.
    Apr 28 2004
    its only channel 1 thats messed up everything else works i try messing with it tonite.
    EVOLUTIONRACEWERKS
    Audi West Covina
    (AKA luvmshavd)
