Results 1 to 11 of 11
    Awaiting Confirmation Two Rings
    Jun 27 2004
    Audi A4 1.8T Quattro
    U.S.
    Brake Engine Light
    Why the F#$% is the brake light beeping and flashing every 10 min? Don't have time to take it to the dealership for a while. Anyone else ever have this problem? If so what was wrong?
    Registered Member Two Rings Satan4's Avatar
    Mar 19 2004
    2004 Audi S4, 1998 Audi ABT 2.8
    San Diego
    Is it only when you press your brakes? The light should only come on when you attempt to hit the brakes, otherwise there is another issue.
    Veteran Member Four Rings giago's Avatar
    Feb 12 2004
    audi a4 1.8t 2002
    Mexico
    Maybe you are running out of brake pads.
    or the sensor is grong.
    Active Member Four Rings
    Do you have a brake light out? In my B5 that was the culprit. But the light worked half the time, and then not. Got a new LED and all was good again.
    Jun 27 2004
    U.S.
    When i'm driving down the highway the parking brake light will flash red and beep. I will check the brake light though that's a good idea, thanks!
    Just a thought. These damn cars know everything don't they.
    Feb 17 2004
    NorthEast
    I have had the same problem, dealer has looked into it three times. They tell me they are getting no fault codes and the pads, fluid and brake system look good. its a PITA!
    buy my wheels!
    Jun 27 2004
    U.S.
    so did it go away or does the light keep flashing and beeping?
    Veteran Member Four Rings Elberoth's Avatar
    Feb 18 2004
    1990 Ferrari Testarossa
    Warsaw, Poland
    Probably the brake fluid level is too low. It happens when your brake pads are about to end. Either add some fluid or replace the pads.
    2021 Audi R8
    2012 Porsche Cayenne
    2010 Audi S5 - facelifted F & R (sold)
    2010 Audi Q5 2.0TDI facelifted F & R (sold)
    2002 Audi A4 1.8T Sportec K04 Stage II (sold | will be missed)
    Jun 27 2004
    U.S.
    k , thanks alot!
    Jun 27 2004
    U.S.
    I called the dealer and he said its the brake fluid and to come down and they will refill in a couple of min.
