Results 1 to 14 of 14
    Registered Member Two Rings Steve's Avatar
    May 27 2004
    Toronto GTA
    does anyone know the difference between xenon and non xenon ecodes?
    um well at ecs tuning (http://www.ecstuning.com/stage/edpd/...egory=Lighting) they sell two types of headlight replacements one for xenon and one non xenon what is the difference seeing as neither come with xenon components and i assume they both have projectors?
    Veteran Member Four Rings RedRocket's Avatar
    Feb 12 2004
    Toronto GTA
    A few differences.....
    1. Cut-off shield in the projector. The beam pattern is controlled differently in Xenon projectors.
    2. Type of bulb required. HID will require a D2S bulb. Halogen will require an H7 base bulb.
    3. The bottom of halogen projectors is closed whereas the HID ones have an opening to mount ballasts.
    There may be more but these I know....
    Active Member Four Rings
    Pretty much summed it up.
    Feb 17 2004
    Sterling, VA
    Thumbs up
    Steve,
    You car looks really frikken shinny in that pic. Looks awesome.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Account Terminated Four Rings MR VTEC's Avatar
    98.5 Audi 1.8TQM
    Brooklyn
    yall forgot PRICE!
    Yeah, that comes into play eventually.
    Veteran Member Four Rings skene's Avatar
    Feb 13 2004
    Las Vegas
    Huh?!?!?!
    The cut off is the same between Xenon and Halogen E-Codes... difference is just the simple fact that it has cut outs in the bottom for the OEM ballast.
    The projection glass is different between US-Spec and E-Codes for the simple fact that the US-Spec has ridges embossed into the glass vs a smooth surface on the E-Codes.
    Other than that everything else you mentioned is correct.
    2017 Toyota 86
    May 20 2004
    More cars
    Never Land Ranch
    since the DOT spec lights are glass, will they ever suffer from rippeling?
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    May 27 2004
    Toronto GTA
    Originally posted by Daft
    Steve,
    haha thanks...i think thats after a wash...i just finished waxing it and shit gonna post some pics soon
    Feb 12 2004
    Toronto GTA
    Originally posted by skene
    Huh?!?!?!
    Are you sure about that? I was told the cut-off is different and if you put HIDs into halogen projectors, you will get a very sharp cut-off, but not with the HID projectors. Have you taken them apart before? I haven't.
    May 20 2004
    More cars
    Never Land Ranch
    i remember hearing somehting like the projector lenses were in some way different.
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    Feb 12 2004
    Toronto GTA
    The actual lens is not different from halogen to HID. Except when compared to ecode projectors.
    May 20 2004
    More cars
    Never Land Ranch
    sorry i meant the lens from DOT from E-Code Xenon
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
