Results 1 to 1 of 1
    Registered Member Two Rings Steve's Avatar
    May 27 2004
    Toronto GTA
    JL Audio e1200 amplifier brand new never opened!
    Specifications:
    Rated Power (mono):
    120 W RMS x 1 @ 4 ohm (12.5V);
    200 W RMS x 1 @ 2 ohm (12.5V)
    THD at Rated Power:
    <0.08% @ 4 ohm (20 Hz -20 kHz)
    S/N Ratio:
    >104 dB referred to rated power (A-weighted, 20 Hz – 20 kHz noise bandwidth)
    Frequency Response:
    10 Hz – 25 kHz (+0, -1dB)
    Damping Factor:
    >200 @ 4 ohm / 50 Hz,
    >100 @ 2 ohm / 50 Hz
    Slew Rate:
    ± 22V/µs
    Input Range:
    200mV – 8V RMS
    Dimensions:
    9.8" x 9.25" x 2.36"
    Features:
    Absolute Symmetry™ Class AB Circuit (U.S. Patent #6,294,959)
    Differential, Noise-Cancelling Input Topology:
    RCA jack inputs (low-level) and multi-pin jack (high-level)
    On-board Crossover:
    State-variable, 12dB/octave Butterworth with continuously variable cutoff frequency selection from 50 – 200 Hz. Configurable as Low-Pass or High-Pass
    Preamp Output:
    Pass-through type.
    Speaker output connections:
    accept up to 8 AWG wire
    +12V and Ground connections:
    accept up to 4 AWG wire
    asking 350 (can)
    brand new...
    please pm me or email at [email protected]
