Results 1 to 18 of 18
    Veteran Member Three Rings chaua1's Avatar
    Jul 29 2004
    99.5 A41.8TQM
    Colorado
    Sorry, one last ? about CC mod.
    From AW's tech article: http://www.audiworld.com/tech/ext.html
    It says to drill the two holes in the back of the headlight housing. How does one know where to drill EXACTLY? I want to only drill the necessary holes, meaning I don't want to drill away half the unit looking for these orange tabs. Anyone know a "rule of thumb" for looking for the right spot to drill?
    Thanks guys!
    Adam
    "The whistle goes woooo wooooo"
    <img src="http://www.audizine.com/gallery/data/500/2939sig.JPG">
    Veteran Member Four Rings D Piddy's Avatar
    Feb 12 2004
    Me: 2010 B8 A4 S-Line In the Family: BMW Z4M, BMW 335xi, Range Rover Evoque, Honda Element
    Washington, D.C.
    u can see where the tabs are from the front, so just imagine al ine going straight back and drill at that point. i found it helped a lot to pull up that rubber weather strippign that goes along the side of the light so that i had a complete view of where i was dremeling. then u can just glue that stripping back on after, worked out fine
    Active Member Four Rings
    Drill from the top and bottom. Not behind the tabs.
    GTA, Canada
    Evil you drill through the clear headlight part right.
    RippleChip (Ryan) - Moderator
    Audizine
    01.5 eh4 1.8T || 12 eh5 2.0T
    Yeah, just too easy to break the tab in that direction and not go to far into the headlight at all.
    Jun 23 2004
    nj
    do yourself a favor, do not drill out the orange tabs, drill into the back of the headlight unit through the black part, then get a real fine flat head screwdriver and pop, or snap the orange tabs off. other wise u may drill too much of the ornage tabs out and have big hole showing in the clear part of the headlight, aka what i did the first time......
    If you drill through the clear part you aviod that exact issue.
    Jul 29 2004
    99.5 A41.8TQM
    Colorado
    So I would be drilling from the front of my headlights?? Wouldn't that make a really ugly hole?
    Adam
    Not the front. The top and botom sides. It's clear there if you peel back the black rubber on top. You can see the little tab stickig out there and it's easier to get to.
    Jul 29 2004
    99.5 A41.8TQM
    Colorado
    As always, thx again Evil!
    NP, loks Like I'll be doing another one of these this week. I'll try and get progress pics as I do the CC.
    Veteran Member Four Rings RedRocket's Avatar
    Feb 12 2004
    Toronto GTA
    The tech article on AW is missing that "Pull back on the black rubber strip" part.
    Feb 12 2004
    Washington, D.C.
    it's not necesary, just helpful
    Veteran Member Four Rings Pureaudi's Avatar
    Jun 23 2004
    97 a4 1.8t
    San Jose
    im gunna do that soon too
    Jul 29 2004
    99.5 A41.8TQM
    Colorado
    Well I did it, took about 3 hours. I'll post pics tommorow since its all dark outside. Hey thanks again Evil, I've been wanting to do this for awhile but was unsure on what to do.
    Adam
    Pureaudi, do it! It's worth it, well of course since its free. Haha
    NP, and I do it my own way. I don't really give a crap what the AW tech article says how to do it.
    Feb 12 2004
    Washington, D.C.
    wut a rebel
    I simply found the way I do it the easiest and least intrusive to the housing. Done so many, that it's become no biggie.
