Results 1 to 11 of 11
    Veteran Member Four Rings S4audi_SD's Avatar
    Jun 05 2004
    Current: 03 A4 Prev: 05 S4
    Oceanside, CA
    hyperboost or forge DV
    i'm getting a DV this week and want to see what people recommend
    Veteran Member Four Rings astris's Avatar
    Mar 03 2004
    nothing
    San Diego
    I was in the same boat. I think I'm going to get the new Stratmosphere Hyperboost HX. Supposed to be pretty good. Go hit up Group5motorsport, they carry them and can give you a good price.
    santa monica CA
    All DV are similar...just get whatever you want
    Veteran Member Four Rings fongaroos's Avatar
    Feb 12 2004
    cali
    i had the FORGE DV but none of the rest so i cant offer you a comparison...
    but my experience with the forge was excellent. its VERY WELL BUILT and its really heavy duty...
    Registered Member Two Rings Diesel'S4's Avatar
    Aug 07 2004
    '04 S4
    PA
    i ran a Hyperboost on my Jetta, and never had any issues...
    it was pretty solid... instant boost on throttle application...
    Veteran Member Four Rings DLSJ5's Avatar
    Feb 12 2004
    2005 M3 ZCP
    LA, CA
    Flip a coin, they're both very good. I'm running the Strat Adjustable Hyperboost, but would go with a Forge as well. Can't go wrong with either. If you get the Forge install it backwards as it's supposed to work better in that position, the Hyperboost just install normally.
    Jun 05 2004
    Oceanside, CA
    yeah, i think i'm going with the hyperboost, i getting it done at group5 this week hopefully
    I spent 8 years touring the world in a rock band...now I do nerdy piano composing and movie scoring, and my obsession with cars and being a member of this community for a decade has lead me to start SD Wrap (www.sdwrap.com).
    IG: RaminIFAF
    SDWrap
    Feb 12 2004
    cali
    yah the spring tension on the FORGE is pretty high. its a really solid DV. and the combination of the vac line and the charged air helps to push the piston open. i installed it the right way and it still worked fine but ive heard that the FORGE works better installed backward too...
    Mar 03 2004
    nothing
    San Diego
    Why would it work better backwards??? If that was the case why wouldn't they just make that the normal installation?
    Feb 12 2004
    cali
    ohh mang...
    not this again...
    lemme try to find the link...
    http://dv.mistertam.com/
    check that out... hope it helps...
    there were a few threads about this lately...
    lots of different opinions lots of different results...
    just gotta sort through it all and try to figure out whats best for you
    Veteran Member Four Rings jeremy@matrix's Avatar
    May 27 2004
    B8.5 S4, B8 S4, B7 A4A, B6 A4, B5 A4, Q7, 958TT, 955TTS, 997C2S, 996TT...
    Portland, OR
    We highly recommend the Forge 007P or the Dahlback Racing DV(a little smaller than the Forge).
    We have both in stock and offer same day shipping. Let me know if we can help at all.
    Best,
    Jeremy
    Jeremy Williams
    Matrix Integrated Inc.
    www.matrixintegrated.cc
