Results 1 to 7 of 7
    Feb 23 2004
    audi, vw, 72 bronco
    ne, pa
    where the he!! did the.....
    control arm thread go? i thought i was on it yesterday and i was going to print it out at home and now i can't find the damn thing.
    the whole turbo90 w/ torque specs and everything...
    thanks
    Veteran Member Four Rings skene's Avatar
    Feb 13 2004
    Las Vegas
    guess it's gone. Maybe it's in the technical section? moved by moderators.
    2017 Toyota 86
    GTA, Canada
    Did you try searching. I'm not sure which thread you're referring to.
    RippleChip (Ryan) - Moderator
    Audizine
    01.5 eh4 1.8T || 12 eh5 2.0T
    Veteran Member Four Rings Burntaudi's Avatar
    Sold:1997 Audi A4
    Maplewood, Minnesota
    Alex
    Sold 97 Audi A4 Turbo Quattro Manual
    KO4/GIAC PC-16/GHL Exhaust/EVO FMIC/ Southbend Clutch/JHM Short Shifter & Linkage/Shifter Bushing/Koni Coilovers/Neuspeed Sways/17" OZ Superellegras/Ecode Headlights/VVME Hids
    Current ride 03 Tahoe Z71
    Feb 23 2004
    audi, vw, 72 bronco
    ne, pa
    thanks burnt. i did a search and i could not find that one. i have been beating on the long bolt with the top two arms for about 2 hrs. now any body have any suggestions?
    thanks
    Veteran Member Four Rings RedRocket's Avatar
    Feb 12 2004
    Toronto GTA
    Keep spraying WD40/rust penetrate, while tapping one end of that bolt, put a wrench on the other end and try turning it at the same time(this may require you to grab a case of beer and call one of your buddies. I had fun with that bolt too and I was also using an air chisle
    Feb 23 2004
    audi, vw, 72 bronco
    ne, pa
    the best part is there are no more ends to the bolt. completely broke off so i started drilling the bolt out. was going good until ... yes a bit broke off in the whole. that f'n bolt will not move at all... now i have to figure something else out to get the damn bit out....
    later
