Results 1 to 3 of 3
    Registered Member Two Rings
    Feb 25 2004
    What is the correct offset for 9 inch in the rear?
    Im gettting 19's and I want to put 9 inch wide in the rear but someone tell me the correct offset without rubbing. I have neuspeed sport springs. any help would be nice and personal experiences..
    Feb 25 2004
    bump
    Veteran Member Four Rings nadroj81's Avatar
    Feb 12 2004
    Albany
    call HRE, tell them you want to get a set of rims that are 9'' wide, they will tell you waht the offset should be, also if you are running a BBK, You will be able to find the range of offset. BBK=small lip, Big lip=no BBK.
