Results 1 to 12 of 12
    Registered Member Three Rings sighpost's Avatar
    Jul 16 2004
    1999 Audi A4
    Jacksonville N.C.
    Turbo Timer need speed signal wire
    I got my turbo timer working. It is a greddy full auto turbo timer but in order to get teh full auto feature to work I need to tap the speed signal wire or speedometer wire. Does any one know where to do this and more importantly what color is the wire. Also any hints on how to tap the parking break wire with out taking my center console apart.
    Man I am glad this thing finally works and btw big thanks to Zodiak.
    Neuspeed P-Chip 1.0 Bar(5 Bar FPR)::Greddy Full Auto Turbo Timer::GFB DV::HKS Intake::Yellow Konis and Neuspeed Race Springs
    Jul 16 2004
    1999 Audi A4
    Jacksonville N.C.
    Anyone here own a Bently manual. Can you look up the Speed signal wire please? (MPH not engine speed)
    Veteran Member Four Rings 4ingDrive's Avatar
    Feb 25 2004
    Chi town burbs
    Should be pin three of connector T32. White/blue.
    99.5 A4 Avant
    always some shit broken
    Registered Member Four Rings Zodiak's Avatar
    Washington DC
    glad you finally got it working. It was always my understanding that the TT's "features" don't work with our cars since they don't make harnesses for it but maybe I'm wrong. As for the parking break feature, just take out the center console, it's not too hard, a few screws hidden behind the plastic covers near the front of the driver's and passenger's seats, some more under the cup holder next to the e-brake (just pull up on the cup holder) and one under the rear seat ashtray IIRC.
    Although, the parking brake feature isn't that necessary. When you remove the key, the steering locks, so any wanna be theif wouldn't be able to steer at all. Also the TT has a saftey feature where if you add more time once it's counting down, it makes a very annoying high pitched noise. The only way to stop the noise is to turn off the timer, which means turning off the car. So it's up to you, but I wouldn't say it's that necessary.
    Jul 16 2004
    1999 Audi A4
    Jacksonville N.C.
    [As for the parking break feature, just take out the center console, it's not too hard, a few screws hidden behind the plastic covers near the front of the driver's and passenger's seats, some more under the cup holder next to the e-brake....
    Try to do the ebrake thing but no luck. Apparently the TT needs signal on a 12V circuit for the feature. I tested the parking break wires with a voltometer and the voltage is much lower (like not even 1 V). But I tried anyway and sure enough it did not work.
    Thanks to 4inDrive. Ill try to find that wire and give it a try.
    In the mean time enjoy the picture.
    Jul 16 2004
    1999 Audi A4
    Jacksonville N.C.
    OK it is the blue and white wire as 4indDrive said. And as it turns out the features DO work so I now have a digital speedometer and TACH. It can stuff like record top speed and 0-200 km times and what not. Pretty cool gadget all in all.
    Registered Member Three Rings BoostinA4's Avatar
    Jul 12 2004
    where is the wire, and what did you have to remove to ge to the wire , i have the same turbo timer, did you hook up the ebrake wire also, and if you did how??
    http://www.audizine.com/gallery/data...765sig-med.jpg
    http://www.cardomain.com/memberpage/589435/4
    -----FOR SALE HERE!!!-------
    ATP manifold
    T28 wastegate
    440cc greentops
    RS4 bumper
    (2) Sparco 3pt harnesses
    HKS ssq BOV w/adapter
    (2) 4 bar FPRs
    Feb 25 2004
    Chi town burbs
    It's one of the harnesses going to the cluster. For the auto features just tap into the ebrake's wire. It should go to ground when it's on.
    99.5 A4 Avant
    Jul 16 2004
    1999 Audi A4
    Jacksonville N.C.
    No the parking break feature wont work. You have to wire the brown TT wire to the parking break wire. We have 2 parking break wires. The TT instruction manual says to wire it to the wire that has 12V when the brake is engaged and 0V when it isn't. I tested both wires and only one of them has a signal when the brake is engaged and it is like .1V. Must be a difference between Japanese and Euro cars. I tried hooking it up anyway just to be sure but niether wire seemed to work. I just dont think it is possible. As far as teh speed wire I tapped it at the back of the ECU. It is the blue and white wire. If you are looking at your ECU from the front of the car than take off the harness on your right. It is the bigger of the two harnesses. Then strip away some wire and hook up the purple TT wire. You will need to calibrate it. The instruction manual describes how. IT is pretty accurate. It uses the speed signal to calculate RPM. You also have to calibrate the RPM feature.
    Feb 25 2004
    Chi town burbs
    I've never seen a parking brake wire that went to +12v but anyway that could be solved with a relay. You also don't need to go to the ecu for the speed sense wire. It's right on the back of the instrument cluster.
    99.5 A4 Avant
    Jul 12 2004
    how do you calibrate it, i think i lost my turbo timer booklet
    ATP manifold
    T28 wastegate
    440cc greentops
    RS4 bumper
    (2) 4 bar FPRs
    Jul 16 2004
    1999 Audi A4
    Jacksonville N.C.
