Results 1 to 10 of 10
    Registered Member One Ring abuC's Avatar
    Aug 03 2004
    4.4L Inline 10 44valves ;)
    Mount Vernon, NY
    Supra sidemount?
    Has anyone here ever used a Supra side mount intercooler? I know the DSM guys use it, and it's efficient up to around 450hp.
    You can find them on Supraforums.com for about $300-$400 too.
    DSM with a Supra SMIC
    Veteran Member Four Rings skene's Avatar
    Feb 13 2004
    Las Vegas
    why would you? Just because it is good for up to any HP.. that doesnt mean squat.
    2017 Toyota 86
    Aug 03 2004
    Mount Vernon, NY
    Because it's an efficient & cheap intercooler.
    Feb 13 2004
    Las Vegas
    if it was efficient and cheap.... more people would be doing it on their A4s... but modifying any parts like that does not come cheap.
    2017 Toyota 86
    Aug 03 2004
    Mount Vernon, NY
    How many people even know about the Supra side mount in the first place? Maybe if they did, they'd be running it, like I said before the DSM guys run it and it keeps charge temps low on their cars. Look, if the SMIC can do the job on a 400whp Supra or Dsm running a 20G, Im sure it can do a very good job on a KO4 A4.
    And it would be much cheaper than running a FMIC. I just found one on Supraforums for $115.....
    Veteran Member Three Rings chaua1's Avatar
    Jul 29 2004
    99.5 A41.8TQM
    Colorado
    Not a bad idea, might be worth it to do the custom piping. I was also thinking about using my friends spare front mount starion intercooler if I decided on a ko4 setup.
    "The whistle goes woooo wooooo"
    <img src="http://www.audizine.com/gallery/data/500/2939sig.JPG">
    Registered Member Three Rings sighpost's Avatar
    Jul 16 2004
    1999 Audi A4
    Jacksonville N.C.
    do you know if there are any fitment issues? Also do Supras have vented wheel wells? I think if you do this conversion it would be worth it to put in S4 wheel wells for better circulation. You will might need new software too if the IC much bigger.
    Neuspeed P-Chip 1.0 Bar(5 Bar FPR)::Greddy Full Auto Turbo Timer::GFB DV::HKS Intake::Yellow Konis and Neuspeed Race Springs
    Feb 17 2004
    Sterling, VA
    At one time, I had 3 different MKIV Supra SMICs in my garage. I have tried the MKIV Supra SMIC on my old 1G DSM paired with a Big 16G at boost pressures from 15-20Psi. The unit is better at reducing knock than a stock DSM SMIC but, the piping and couplers that I had to rig up were a nightmare. In terms of actual performance, it was slightly better. I suspected that the extra pressure drop with this unit was due to the larger end tanks.
    The MKIV Supra IC is a well sized SMIC but, the stock A4 SMIC is very close width and height. The only real noticeable difference is the thickness of the core.
    I'm not saying you shouldn't try one on your A4 but, I can't see it make a large difference in charge temps. Besides, the main problem with the 1.8T isn't heat soaking, it's that we have a turbo that's too small and very fragile.
    Here's what the stock 1G DSM SMIC looks like next to the MKIV Supra SMIC:
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Jul 29 2004
    99.5 A41.8TQM
    Colorado
    Ah, thanks for your input daft.
    Aug 03 2004
    Mount Vernon, NY
    Good input, I'll probably give it a shot, since the IC is just too cheap it pass up.
    As for small fragile turbos, I will be going with a KO4, or possibly T-28
