Originally posted by R3DL3TR5
Hey, I'm looking into replacing my stock DV with either a Forge or an evo. I've been reading up on both and they both seem to be equally as effective, however, i'm just looking for a suggestion from you guys. Which one would you recommend? Also, I want to put an intake on. (probly warm air because i need to use it in the snow and winter). I was looking at the evo, and i really like it's setup but it seems kind of pricey. I'm looking for the best sound and best performance gains. Also, what kind of performance gains can i anticipate by changing these (DV and intake). What are my other options and what all would you recomend? Thanks!
-wes m.
back on the subject... These are my opinions, all of which I believe to be true. You may take these as "fact" if you wish, or not, it's up to you.
I don't think a "warm air intake" would be worth it, even in the snow. Once the enien warms up, your going to have a hard time getting the volume of air into the engine for optimal performace... hot air is less dense, therefore you have to flow more air to get the same amount of oxygen. Besides, once the engine is warm, it WANTS cold air.
There are very little performance gains with the CAI, as DDQ stated. The OEM setup has excellent heat shielding for a small 1.8t.
Performance gains from a BPV are barely noticable unless something is already wrong. There are several reasons to get a BPV.
1) Holds more boost - if you are chipped or going above the stock 7 psi, a stronger valve will last longer and eliminate surging. Surging happens when a weak BPV can't hold the boost and leaks some of it to the intake return.
2) metal BPVs last longer. Some are servicable so you don't have to replace them, just lube them.
3) sound - BOV deliver in this category, but if you do a search you will find out that its generally not recommended to use one in our cars unless you run a recirculation kit, which = $$$$. Metal BPVs combined with CAIs don't sound as loud as BOVs.
