Results 1 to 29 of 29
    Veteran Member Three Rings chaua1's Avatar
    Jul 29 2004
    99.5 A41.8TQM
    Colorado
    1.8T chipped/exhaust vs. S4
    Just wondering how a chipped A4 with exhaust would fare against an S4? Anyone ever raced their friend's S4?
    "The whistle goes woooo wooooo"
    <img src="http://www.audizine.com/gallery/data/500/2939sig.JPG">
    Feb 12 2004
    99.5 1.8T A4
    Cleveland OH
    the S would murder you!
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    you would die a horrible death unless the S4 didnt know how to drive. He will still have almost 40 hp on you.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    Registered Member Three Rings AFOUR_PLAY's Avatar
    Apr 15 2004
    Sydney, Australia
    What about S4 Vs A4 with KO4 kit?
    Daniel
    http://smileys.smileycentral.com/cat/3/3_2_116.gif
    A4 1.8T Quattro - Clicky Here
    -Stoptech Brake lines - RS4 Grille - DIESELGEEK SS - GFB DV - APR Snub Mount - K04 Turbo - Samco Turbo Inlet Hose - S3 injectors - GIAC - 18x8.5 1/16 Carlsson copy 18/40/235
    Feb 12 2004
    99.5 1.8T A4
    Cleveland OH
    you'll still die, just not as bad!
    Veteran Member Four Rings Devious27t's Avatar
    Mar 02 2004
    2001.5 S4 Avant on Corn
    Orange County
    Re: 1.8T chipped/exhaust vs. S4
    you will be fine just make sure you bring the lube or it might hurt a little
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Re: Re: 1.8T chipped/exhaust vs. S4
    rotfl!!!!
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    Audi B5 A4
    Veteran Member Four Rings skene's Avatar
    Feb 13 2004
    Las Vegas
    would that S4 be chipped with exhaust as well?
    The only way you would be taking out one of those is if during the race both of the S4s turbos went.
    2017 Toyota 86
    Active Member Four Rings
    I raced an X chipped S4 with my car and was a foot ahead of him till a bit through 2nd gear where he raped me. Long terms race won't happen.
    Veteran Member Four Rings RedRocket's Avatar
    Feb 12 2004
    Toronto GTA
    lol! and don't forget the knee pads.
    Feb 13 2004
    Las Vegas
    and elbow pads...
    its going to be rough.
    2017 Toyota 86
    May 02 2004
    99.5 1.8tqm
    Flemington, NJ
    ive read a k04 kit with the right tuning can pull on an s4 up until 60-70mph, then its over
    4 wheels
    2 headlights
    1 glovebox
    1 ac unit
    1 radio
    1 engine
    Depends on if the S4 is chipped or stock.
    Feb 13 2004
    Las Vegas
    maybe on a good day....
    an S4 also has close to double the displacement and 2 turbos.
    2017 Toyota 86
    Veteran Member Four Rings DRA4's Avatar
    Feb 12 2004
    B5 S4
    S4 will own you, plus with a chip, it is a torque monster.
    Giac stage 1 279whp-327wtq
    TEAM A.C.E. NY
    Me: Siri where do lesbians hang out?
    Siri : I found 2 Subaru dealers fairly close to you
    May 04 2004
    00 BB S4
    York, Pa
    It's alot about driver skill also...the A4 with a perfect launch could stay infront through first and second, but once past that... theres no way...
    00 S4 BB Stg3
    Stolen Tune|K&N|STACK|DAR|KW V1|VAST - MBC |JHM SS Knob - SS lines - FMIC - Shifter - Trans Rebuild - 2pcs Rotors|AWE DTS - Boost Guage - DPs |BW K04|Southbend Stg 3|ASP Cat Back|V1|034 Snub - Race Tranny mount - Street Motor Mounts - Intake Hose - DVs|HAWK HPS|APIKOL RDM|H Sport RSB|6000k HID|Mille 12"|Hifonics|Focal|WOTBOX|AVIC910
    Jul 29 2004
    99.5 A41.8TQM
    Colorado
    Lol, I guess I'll be staying away from my brother's S4 for a while.
    Adam
    Awaiting Confirmation Four Rings
    Feb 12 2004
    Albany NY
    There is a video out there, Stage 3 A4 vs. Chipped S4 i think. The A4 gets a killer launch, then the s4 eats him.
    Not only the power but the gearing the the S4 is better in the higher speeds.
    Registered Member One Ring abuC's Avatar
    Aug 03 2004
    4.4L Inline 10 44valves ;)
    Mount Vernon, NY
    KO4 vs Acura TL
    anyone had a run in with one?
    Mar 02 2004
    Orange County
    Originally posted by abuC
    KO4 vs Acura TL
    i could beat them with my K03....
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    ^^^^^^^^^^^^same here, stock with ams stage 2, they arent that great,,, unless the guy didnt know how to drive. i shouls have filled my winshield washer fluid with lube, got in front of him while driving and sprayed him. he had it cumming.
    Established Member Two Rings Numbersix's Avatar
    Aug 06 2004
    Even with a Stg3 car, FMIC, etc...you might want to think twice.
    S4's have far more torque, better gearing, etc. It does offset the weight difference.
    ...be seeing you.
    bucket
    Mar 02 2004
    Orange County
    I have seen S3 cars pull on chipped S4's actually.... when you get into the bigger turbos the tq climbs really fast, and the increased power from an S3 (or more) can actually work better with the long gears (due to the car holding boost longer), weight diff really becomes an issue for the S4....
    I'm us about sure MKGIY's car would pull a S4 easily. The T28 he was running would do it, his new kit would easily do it.
    Aug 03 2004
    Mount Vernon, NY
    Im talking about the 260hp Type-S to be exact.
    Feb 13 2004
    Las Vegas
    I'm sure it would be close.. but if you are talking distance driving... the S4 would just pass over 100+
    2017 Toyota 86
    Account Terminated Four Rings MR VTEC's Avatar
    98.5 Audi 1.8TQM
    Brooklyn
    tl would own you!
    Feb 17 2004
    Sterling, VA
    I've driven the new TL (270HP), Type-s is gone now. The TL isn't really great out of the hole but, it's mid-range power is pretty shocking for the boat that it is. I'd say that a new TL would ass-whoop most chipped A4s in a heartbeat.
    Try the 3.2 CL or a TSX, then you'll have a chance.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
