Results 1 to 8 of 8
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Audi Tune-Up Tutorial?
    Does anyone have a write up on how to do a start to finish tune up on a b6?
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Re: Audi Tune-Up Tutorial?
    Plug in the vag-com. Point the cursor to tune up. Click. Wait 3 minutes. Unplug the vag-com.
    What exactly do you mean by "tune up"?
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Sep 24 2007
    Woodbridge, Ontario
    Like what goes along with this car when it needs a tune up?
    Oil change? Air Filter? Cabin Filter? Plugs? Distributor? Lines?
    Quote Originally Posted by Tgr_Clw View Post
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Appearance: OEM+
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Oil changes should be done every 5K miles using Audi approved 100% synth. engine oil. Air filter every 10-15K. Cabin filter every 10-20K. Plugs - depends on what plugs you're running.
    Appearance: OEM+
    Sep 24 2007
    Woodbridge, Ontario
    Very nice Thanks!!!
    Veteran Member Four Rings Papachristou's Avatar
    Buncha motorcycles
    Memphis, TN
    be sure to change blinker fluid!
    Its like any other car... oil, filter, air filter, spark plugs, coilpacks, brake fluid, coolant, tranny fluid.... it all need changing at some point
    2018 Audi S6 Prestige Sport Sepang Blue/Lunar Silver
    APR Stage 2/AWE Intake
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    dont forget the o-pipe and sesonal tire air...
