    Stage 3 Forum Advertiser Four Rings
    Apr 01 2004
    Orange County, CA
    headlight adjustment
    Can someone show me how to aim the headlights? Thanx. The shop had to do something with headlights when they tilted the motor for some work.
    Feb 17 2004
    Cali
    i'm sure your manual will have your answer. but there are 2 white screw things on the top of the assembly. you can just use a philips to turn. the ones towards the middle of the car adjust the height and ones on the outside adjust right to left. or is it the other way around? someone correct me if i'm wrong. but i think that's it.
    Current car: '07 Audi DTM S4
    Prior Audi's:
    '04 A4 1.8t sedan
    '00 S4 sedan
    Feb 10 2004
    2019 Mk7.5 Golf R His/Her
    Eastvale
    nope that is correct
    Instagram: @daohaus_garage
    Veteran Member Three Rings 1/4 scale's Avatar
    Mar 03 2004
    North Carolina
    Try this reference for manual adjustment.
    http://www.danielsternlighting.com/tech/aim/aim.html
    2002 A4 Avant 1.8T • APR +1 • DSMIC • JJ tip • RS4 mounts • SB OFE HD • Apikol snub • B5 S4 binders • 18" Ultraleggeras w/ Conti D/Ws • APR exhaust • APR TBHose • Stasis SS • S4 rear sway • AMS ss • e-codes • Pzwo lip • S4 blades • USP roof spoiler • Apex track studs
