Results 1 to 8 of 8
Thread: Ko3 questions
    Registered Member Two Rings BoostAddict's Avatar
    Aug 05 2004
    97 1.8tqm, 96 2.8m fwd
    Douglassville Pa
    Question Ko3 questions
    Ok guys, I have been on this site non-stop researching about my newly bought car. I have read many articles favoring different turbo setups over one another. With our stock ko3, what can you do to draw every ounce of power out of this baby? I have read you can get close to 250hp out of a ko3? What modifications would I have to do to make over 200whp? Without going ko4, gt28, t-28...Any comments would help considering I am new in this Audi game. Oh and also, can you boost control Audi's, using, EBC's and MBC's? Because some of these psi levels sound way too high for a chip upgrade? I know im asking a lot, thanks everyone once again!
    Speed Kills, Slow infuriates
    Veteran Member Four Rings Hassmeister's Avatar
    Feb 12 2004
    2015 GOLF R APR Stage 2
    250 hp, I find that very hard to believe without major distruction. That little thing can only push soooo much air before bye-bye.
    Click here for AMSOIL - Superior Protection!
    Wholesale pricing and delivery to your door - ask me how!
    Feb 13 2004
    <> Posts: 9913
    Getting up to 215 CRANK hp (which is about 160whp on a Quattro) out of the K03 is about as much as you get get, and still maintain some reliability.
    The K03 just gets too hot to boost high, and the high rpms that it spins at make it unstable if you boost in the high teens. It's happiest around 14psi.
    But, later B5 A4 models have a slightly different "sport" K03, which I think is found in the 2001 models. That can handle slightly higher boost and is said to make a bit more power at the higher limits.
    -Theodore Roosevelt, 1907
    Aug 05 2004
    Douglassville Pa
    Hmm...Well I guess the ko4 is in my future then fellas...lol..But on the boost controller thing, can you use one of any kind? People say something about a j31 program that im completely infamiliar with, does that increase boost substantially?.. Thanks everyone
    Registered Member Four Rings Zodiak's Avatar
    Washington DC
    On a stock A4 I would not suggest a boost controller, first get a chip (ups boost and timing, +45hp and about 45lb/ft torque). Once chipped you can run a boost controller but don't expect much from it, the new software will put boost up into the mid-high teens, spiking around (15-18psi) and holding around 10psi. Thats basically the limit of the turbo, so turning boost up much further past that will do more damage than good.
    The J31 software has to do with the k04, not the K03. It's a version of the giac k04 software that runs slightly higher boost and requires larger injectors and a fmic IIRC, compared to the k31 version which puts out a little less boost but does not require anything additional. the j31 software has been know to be a little notchy, but some people claim that they get a noticible amount of more power from it.
    Veteran Member Four Rings RedRocket's Avatar
    Feb 12 2004
    Toronto GTA
    Hey man, I have an extra K03 if you need one
    Veteran Member Four Rings Burntaudi's Avatar
    Sold:1997 Audi A4
    Maplewood, Minnesota
    J31 is also only for Model Year 2000...he's got a 97 so J31 is not even a option for him.
    Alex
    Sold 97 Audi A4 Turbo Quattro Manual
    KO4/GIAC PC-16/GHL Exhaust/EVO FMIC/ Southbend Clutch/JHM Short Shifter & Linkage/Shifter Bushing/Koni Coilovers/Neuspeed Sways/17" OZ Superellegras/Ecode Headlights/VVME Hids
    Current ride 03 Tahoe Z71
    Aug 05 2004
    Douglassville Pa
    Once again you guys come through, thanks everyone, I will just do a ko4 and hope for the best. The other turbo upgrades are a little pricey so.. Oh well, thanks again!!
