Results 1 to 19 of 19
    Registered Member Two Rings
    May 26 2004
    2006 4runner
    No owners manual , need help please
    For the last 2 days on the diplay in the instrument cluster I have this yellow circle poping up with two brackets around it after a few minutes of driving , folowed by a short beep.My car is a 2001 A4 1.8T. Can you please look in your manuals and tell me what it means.
    Account Terminated Four Rings Neo1130's Avatar
    Aug 12 2004
    Audi A4, Audi TT
    Oklahoma City
    Brake pads worn... Time for a change!!
    May 26 2004
    2006 4runner
    Thanks man ,I tought its something worst.
    Aug 12 2004
    Audi A4, Audi TT
    Oklahoma City
    Little piddly crap like that will be yellow and bad stuff will be red... If you see red down there... STOP...
    Veteran Member Four Rings RedRocket's Avatar
    Feb 12 2004
    Toronto GTA
    It may be your speed sensor. Our cars, at least in 97, are equipt with a sort of speed alarm. Once you reach a cetain speed it will beep and go away. You can set it at whatever.
    If this were the case it would beep every time you cross that certain spped that you've set it at.
    Does the circle say MPH in the middle?
    May 26 2004
    2006 4runner
    No it is empty in the midle and it has to brackets around it and it comes of at different speeds shortly after I start driving
    Feb 12 2004
    Toronto GTA
    oh cool. Well time to change the breaks then.
    DIY!!!!!!!!!!!!!!! DIY!!!!!!!!!!!!!!! DIY!!!!!!!!!!!!!!!
    Mintex redbox pads, some X-Drilled rotors, Slider/bearing grease, that sould be it if your car is an 01' and everything isn't all rusted to shit. You will save big $$$$$. The dealer is a total thief when it comes to breaks.
    .......it's a dirty game yo.
    May 26 2004
    2006 4runner
    Wich rotors are better for everiday driving , the drilled or sloted?
    2007 2.0TQuattro 6spd S-Line
    Veteran Member Four Rings skene's Avatar
    Feb 13 2004
    Las Vegas
    ok I think it is time for you to go out and buy a manual... dont you think?
    2017 Toyota 86
    Feb 17 2004
    Sterling, VA
    Ebay has lots of OEM owners manuals floating around. Bentley Publishers has them too but, they aren't the cheapest.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Registered Member One Ring A4SilverT's Avatar
    Apr 18 2004
    Northern Virginia
    Which rotors are better for everiday driving , the drilled or sloted?
    There have been some long technical discussions here and on Audiworld on this subject. Search! The way I read the debate was that drilled rotors are totally useless and slotted rotors have only marginal value for clearing dust. In short, for everyday driving, you don't need either.
    Spend your money on better pads and/or bigger calipers.
    A4SilverT
    Feb 17 2004
    Sterling, VA
    ^^^^^I agree 100%.
    Brett - Moderator
    Issue?: email me.
    Active Member Four Rings
    Feb 18 2004
    Audi A4
    East Aurora NY USA
    Brembo blanks = good enough :)
    i like my black girls clean and my white girls dirty.
    doesn't matter either way they're all out to hurt me.
    Veteran Member Four Rings Burntaudi's Avatar
    Sold:1997 Audi A4
    Maplewood, Minnesota
    A4SilverT
    I agree for the most part...except for one thing I did notice when I was runing sloted front rotors it made my wet braking much better.
    Alex
    Sold 97 Audi A4 Turbo Quattro Manual
    KO4/GIAC PC-16/GHL Exhaust/EVO FMIC/ Southbend Clutch/JHM Short Shifter & Linkage/Shifter Bushing/Koni Coilovers/Neuspeed Sways/17" OZ Superellegras/Ecode Headlights/VVME Hids
    Current ride 03 Tahoe Z71
    Feb 12 2004
    Toronto GTA
    Oh are you talking about that slight delay in breaking if it is wet out, and you haven't touched the breaks for a few minutes?
    Sold:1997 Audi A4
    Yes exactly the slots seem to help evacuate the water from the surface of the rotor...so you get faster brake response in the rain.
    Alex
    Feb 17 2004
    Sterling, VA
    I fixed the rain problem on mine. I bought a set of the revised brake disc shields from Audi:
    http://www.audiworld.com/tech/wheel31.shtml
    Works like a frikken charm.
    Brett - Moderator
    Issue?: email me.
    Sold:1997 Audi A4
    I thought about doing that too but now that I did the A8 upgrade I'm not sure if they will fit or not.
    Alex
    Feb 17 2004
    Sterling, VA
    They won't fit right now but, you could always dremel the lip off the end on the shields and at least cover most of the disc surface from splashes. There is also the plastic guards that attach to the belly pan. They are part # 8D0 698 998 A.
    I bought the shields and the plastic guards from Impex for about $22 for both kits. I believe they were $11 ea.
    Brett - Moderator
    Issue?: email me.
