Results 1 to 19 of 19
    Active Member Four Rings Ben@SpeedBarn's Avatar
    03 A6 2.7t, 00 GTI, 76 GMC
    Pittsburgh, PA
    Question Foglight Mod Problem....Help please
    Ok I did the foglight mod on Blacka4s car and my S4. We both seem to be having the same problem. Every once in a while when i start the car the foglights will be on. Sometimes it is the front sometimes it is the front and back. It doesn't matter if they are on before or after i shut off the car. It's weird. I;m thinkin maybe the solder is cracked and the on off of power is kicken them on when i start the car. I have no clue. But it also seems wierd that the solder would be cracked on both of these units. Have you guys experienced this at all. This would pertain to 99.5 and newer foglight mods.
    Forum Moderator Four Rings blacka4's Avatar
    Dodge RAM 1500
    Pittsburgh Area
    cool thanks ben for postin this up. I havn't had the time ot even think about repairing it. if it goes up in flames thats what insurace is for
    -Rob - Moderator - PM Me!
    RIP:1999.5 Audi A4 1.8TQ Tip Brillant Black
    2009 Dodge RAM 1500 Crew Cab Sport - AZ Plate Frame - Bone Stock otherwise
    2014 Jeep Grand Cherokee Summit
    I think you for sure have an issue with the way it's wired. Recheck all those connctions. I've done a few of those and never had an issue.
    Registered Member Four Rings Zodiak's Avatar
    Washington DC
    make sure you clipped the pins as short as possible, and make sure you bridged the correct pins together.
    Awaiting Confirmation Two Rings PDX-Mike's Avatar
    Apr 26 2004
    Portland, OR
    You know, I'm having this same problem....I just thought it was a side effect of doing the mod. I'll have to check it out tomorrow.... Any other suggestions?
    Veteran Member Three Rings HomeSlice's Avatar
    Mine does the same thing
    Washington DC
    did all of you guys mod the box by openning it up, or just by soldering a wire externally from one pin to the other?
    Apr 26 2004
    Portland, OR
    I soldered the wire from one pin to another.
    Veteran Member Four Rings needforspd's Avatar
    Mar 05 2004
    Deceased 01.5 A4 1.8tm
    Sylmar Hills
    I soldered wire from one pin to another.
    i have this issue happen very rarely so it doesnt bother me.
    Do you have a need for speed? Then drive it like you stole it!
    Veteran Member Four Rings skene's Avatar
    Feb 13 2004
    Las Vegas
    that does happen to certain cars where the foglights will turn on and off when you first start the car.
    time to say "get over it"
    you should have read up on the mod first.
    2017 Toyota 86
    Feb 17 2004
    Sterling, VA
    Is this the foglights on without headlamps mod?
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Yes
    Pittsburgh, PA
    Yes that is the mod we are talking about. And yes I soldered these two externally. Let me check a few things. I will let you guys know what i find.
    And yeah I will get over it if i try a few things and it still happens. It doesn't bother me except for the fact it makes me think i did something wrong.
    Did you clip the one?
    Pittsburgh, PA
    I can't remember off hand. I think I clipped 3 and soldered 2 clipped and 1 unclipped together.
    Mar 05 2004
    Sylmar Hills
    Should look like this
    Veteran Member Four Rings cj-S4's Avatar
    Not enough space here
    Somewheretown, PA
    I modded mine and it does the same thing everonce and a while. I believe Foo's did the same thing also when he had a B5. I think it is just something that happens for whatever reason. I just turn them off when they are on.
    Apr 26 2004
    Portland, OR
    As long as it's not gonna hurt anything, I'm fine with it. I just turn them off when I start the car.
    But I did have a nasty dream last night of my Audi catching fire and burning to the ground....
    Pittsburgh, PA
    I guess it is because the fog switches are the pulse type. The switches in the dash aren't on or off. They just send a signal when pushed in...and then return to the same position every time. So for some reason the jump of electricity when the car starts must have enough of a voltage to just barely trip the switch in the control module. close enough that sometimes it does it and sometimes it doesn't.
    Does that make sense.
