Results 1 to 9 of 9
    Veteran Member Four Rings knight007's Avatar
    Mar 10 2004
    SoCAL
    Stereo Wiring Harness
    Does anyone know if this will fit our B6?
    Wiring Harness
    Or does anyone have any other resources because I don't want to pay the high price from AutoToys.
    Front Wheel Drive REVO 71r Elim
    Oettinger
    SSR J-Spec
    I still have HONDA blood in my veins.
    GTA, Canada
    I doubt that will work, doesn't look like any adapter on the rear of the deck.
    Look for blaupunkt adapters.
    RippleChip (Ryan) - Moderator
    Audizine
    01.5 eh4 1.8T || 12 eh5 2.0T
    Registered Member Two Rings OOOO's Avatar
    Aug 08 2004
    U.S.A.
    Re: Stereo Wiring Harness
    Wiring Harness
    That one actually DOES work, but only for the basic 12vdc, GND, and REM. The second row will also fit the speakers, assuming your speakers were driven off the H/U to begin with, otherwise it's useless. If you have external amps anyway, this harness will be sufficient, you will still need to rerun your rear door speaker wires independentely, or run them from the rear amp.
    Feb 18 2004
    Rosemead, Ca
    i actually used the VW01
    http://www.cardomain.com/item/SCOVW01B
    what i did was i bought both harness' and tried them both. then i returned the one that didn't fit, which turned out to be VW03
    Veteran Member Three Rings Icon's Avatar
    Jul 22 2004
    audi a4 ultra sport 04
    Orange County
    It will Work I Work at the good guys and thats the one!!!!
    Established Member Two Rings a4kasper's Avatar
    Feb 02 2005
    65 Ford Mustang
    AZ
    ok time to bring a post back from the dead. will this harness work for the B6 Symphony stereo?
    it's the vw03 as above
    www.azaudi.org
    Mar 11 2005
    New Hampshire
    nah...use the VW01 one...you'll still have to get creative with the rear speakers (i personally tapped the output wires of the factory amp)
    this is for replacing the headunit...if you want to integrate the factory headunit into an aftermarket system, however, you'll need a blaupunkt adapter
    <img src ="http://www.dartmouth.edu/~mhart/sig.gif" width = "375" height = "249">
    Mods: Ultrasport bumper*Painted Lowers*APR Chip*Stereo*Rims
    Feb 17 2004
    2000 Civic Si
    Gainesville
    YOu'll need to contact Metra or www.metraonline.com.
    Call their technical department and they have a special harness and kit from europe that will definitely integrate everything into your vehicle with the rear channel amp. I had installed my AVIC-N1 and it worked flawlessly. The harness adapter have RCAs that will plug into your aftermarket headunit and integrate low level into your OEM rear channel amp in the passenger side rear fender. It's all done behind your OEM headunit though.
    Call them and ask for Matt. If you want mine, I'll sell it to you for cheap since I won't need it anymore. My '04 Audi A4 QMT Ultrasport was t-bone by another guy running a red light. Repair cost got ridiculous, so they totaled my Audi.
    Feb 17 2004
    2000 Civic Si
    Gainesville
    Also, I have a 1 day old chiped ECU from MTM and XM satellite radio I need to sell too if anyone interested. Sorry, didn't mean to post in this thread.
