This weekend I will be installing a T3-T04E in my B6 Quattro.
I am using an ATP exhaust manifold (not my favorite, but it will work). I have a Tial 38 mm external wastegate, and my downpipe will be fabricated at a local exhaust shop out of 3 inch mandrel bends that I have bought.
The fueling will be provided by Bosch 440cc injectors (unfortunately the B6 does not have a fuel return line to the tank or a fuel pressure regulator, so the boost/timing will have to adjusted to the static fuel levels)
Charge temperatures will regulated by a Eurocode FMIC.
The boost will be controlled by an APEXi AVC-R, and the timing will be controlled by REVO SPS3.
I plan on using REVO software from Eurocode since David has spent a great deal of time doing BETA testing for the Audi 1.8t.
I feel that some of the benefits of going big turbo over say a E05, or K04 sport is that the larger turbo is working in the middle of its efficiency range as opposed to te upper 90 percent range for a modified KKK type of turbo. This leads to much cooler EGTs and charge temperatures.
Another reason that I coose to go this route is that by replacing all of the factory components with a bolt in replacement unit, it will be much easier to return the car bay to OEM, so I choose.
I will document the install for everyone to see, and will be very happy to answer any questions regarding how things are going/went.
