Results 1 to 14 of 14
    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2017 B9 A4 Quattro/DSG/Technik/S-Line... 2004 B6 A4 1.8T Quattro race car
    Montreal, Canada.
    Just an update to a thread on AW in regards to the newly released PSS 9 kit...
    Available to the B6 crowd. BTW, the B5 boys can't even get that kit, so....
    Just spoke to Bilstein USA in California.
    The North American version uses the same shock housings as the Euro kit but are valved differently (softer). The bad new continues (for people looking to track their cars), The springs are indeed the progressive type and not the linear ones like in Europe. This was done at Bilstein USA's request because they felt the Euro version was to stiff and uncomfortable for North American roads, too bad!
    BTW, the full retail for that kit is $2250.00.
    Feb 10 2004
    2019 Mk7.5 Golf R His/Her
    Eastvale
    OMG this is like the 2nd coming!!! are you sure it's here in the US?!?!??! LOL
    they got in a big teezy because Aaron at Neuspeed wanted to release this kit w/ the NS badging and they put the kabosh on that!
    I hope they release it as it's another good alternative for the consumer all beit not the exact ones from europe
    Instagram: @daohaus_garage
    03 A4 Avant, 85 ABA Golf
    Palo Alto, Ca
    Wow, i would have thought that kit would be over 3k easily.
    Nice.
    Jul 21 2004
    South Florida
    Re: Just an update to a thread on AW in regards to the newly released PSS 9 kit...
    Bro that just sucks,
    I cant believe they screwed us out of the linear rate springs. Plus we get softer dampning. I might as well stick with my current setup. Wanna sell your kit :) Cheers! Mike
    2018 Audi S5
    Gone-
    Veteran Member Four Rings giago's Avatar
    Feb 12 2004
    audi a4 1.8t 2002
    Mexico
    What is the difference whith the linear rate springs & progressive type ??
    Jul 21 2004
    South Florida
    It means no easy $200 swap of springs to try out different spring rates and it means that once again us Americans seem to whine like babies until the Europeans take all of the sport out of a sport suspension (weaker valving). In all serious it's probably still a decent kit for those deciding on street coilovers. It's just not a cheap motorsport kit as I was hoping. cheers! mike
    2018 Audi S5
    Gone-
    Jun 17 2004
    Montreal, Canada.
    You can get it now at Neuspeed for $1600.00.
    Jun 17 2004
    Montreal, Canada.
    Re: Re: Just an update to a thread on AW in regards to the newly released PSS 9 kit...
    On the bright side, for me at least, it means I will remain original a bit longer in the suspension side of things.
    Jun 17 2004
    Montreal, Canada.
    Answer to what the difference is between spring types...
    Well here is the difference. A linear spring as the same spring rate from top to bottom. The coil is evenly spaced throughout its length. Its inner/outer diameter is also the same throughout. The advantage of this spring is best felt in Motorsport application. Because it is linear when a car enters a curve and starts transferring weight and compressing the coils in the suspension, it will do so at a constant or in a linear way until it is fully compressed. The disadvantage to these springs in a street set up is, they are usually stiffer, less forgiving for the ride comfort.
    In this picture, you can see my linear spring made by Eibach and used in the rear of my European and modified PSS 9. FYI, on this spring you can see the manufacturers name, Eibach, the date it was made, 7 months of 2002, the type of spring, ERS which stands for Eibach-Race-Spring, its free length at 200 mm, its inner diameter (ID) at 70 mm, and its rating, here in Newton/mm at 110 which translate into approximately 627 lbs/inch. This means to compress this spring one (1) inch, the car must exert 627 lbs of force.
    On the other hand, a progressive spring is just that, progressive and not constant. It is usually a lot wider at its mid point in the coil with both ends having smaller diameters. Also the space between the coils will be usually different, meaning they will not be constant. This as for effect a softer more cushiony ride level. Good for the street bad for the track. the way it works is that as a car enters the curve it starts to compress the softer part of the coil. As you push further it enters the more linear of stiffer part of the coil. Like I said it is smoother for road use but not as precise for track use. This can be explained the following way. Since Motorsport usually means fast transitions from one curve to another a car with progressive springs will make those transitions harder and more vague for the driver by first compressing rapidly through the progressive part and then abruptly hitting the linear part. This can have as a consequence the car being jerked around by the coils. I don't know if this makes sense to you but it is as best as I can explain it to you.
    In this picture you have a progressive spring. Sorry for the quality of the picture.
    Veteran Member Two Rings Oettinger's Avatar
    Jun 27 2004
    nice write up. :) I learned something.
    Laurence
    2018 BMW M2 Long Beach Blue and 2021 Audi SQ5 Mythos Black.
    Established Member Two Rings teknik's Avatar
    Mar 20 2004
    FL
    whats stopping us from slapping on a set of linear springs? surely the shock body is similar to yours.... as long as the spring rate is within the line of the progressive it should work....
    or could we do some leg work and order in a euro set......
    ///MONEY PIT MOTORSPORTS
    95 318ti S52 Turbo aka The Money Pit
    95 M3 - DD - Green Machine
    Jun 17 2004
    Montreal, Canada.
    According to Bilstein, the shocks are identical. You could change the springs to the linear types but then the valving in the shocks would be all wrong for this new spring rate/ application. You would need to send the shocks back to Bilstein to have them re-valved. Cost at least $125.00 per shock, that's $500.00 plus taxes and shipping. Then add the cost of buying the four springs, another $300.00 perhaps? In the end you might as well order a kit from Europe, it will most likely be cheaper.
    Veteran Member Four Rings neoprufrok's Avatar
    NOR CAL
    Great info Jet. I want to move to Europe now. I wonder what it is that European and Japanese companies think that all out hardcore performance cars/parts can't be sold here? The R32 is doing well, the Evo is doing well, the STi is doing well.
    Currently:
    2018 GT3 Touring - Graphite Blue Metallic
    2016 McLaren 675LT - Mexico Blue with Roof Scoop
    2019 BMW M4 Convertible - Yas Marina Blue Competition Package
    Will be missed: 2001.5 Audi S4, 2004 Audi A4, 2004 Audi A8, 2008 Audi RS4, 2016 Porsche Cayman GT4, 2018 Porsche GT3.2, Mercedes C63 Black Series, McLaren 12C Spyder
    Podcast and Instagram: The Throttle Dogs
    Feb 12 2004
    audi a4 1.8t 2002
    Mexico
    Yes I wan to move to europe too.
    Maybe Italy.!
