Results 1 to 11 of 11
    Veteran Member Three Rings Chillmode's Avatar
    Jul 13 2004
    San Jose,CA
    taking out the amber in the headlight?
    I heard someone was able to take out the amber piece in the headlight of the b6.... is that true? Anyone got directions on how to do it???
    Veteran Member Three Rings Jazzman's Avatar
    Feb 12 2004
    Montreal, Canada
    Re: taking out the amber in the headlight?
    These will give you an idea. It's an easy mod to do. Good luck!
    Here's one
    Here's another one
    “Simplicity is the ultimate sophistication.”
    Registered Member Two Rings Diesel'S4's Avatar
    Aug 07 2004
    '04 S4
    PA
    IMO, this a whole lot of work, and chances are you are going to screw up the insides of your housings, unless you are painstakingly careful... as when you are cutting up the lens there are going to be very small shards that are not going to come out...
    I ran into this problem a few years back with my Galant, and after that debacle, i decided i would never try to clear the corners on any car ever again...
    not to mention the remaining chrome that sits under the amber lens, does not look good...
    Feb 12 2004
    Montreal, Canada
    "A whole lot of work" ????
    It takes 30 min / side to do this mod. This is not a Galant and it's sooooo easy to do. Ecodes are the way to go but if you don't have the $$$, it's a good alternative.
    Established Member Two Rings Kaliman's Avatar
    Jul 20 2004
    Cadillac Escalade
    Mission Viejo
    It takes even less time if you disconnect the autoleveler, tilt up the lenses and slide the amber out the bottom. 10 Minutes max.
    Veteran Member Four Rings Toast's Avatar
    Jul 05 2004
    2014 X3.5m
    San Gabriel
    will you get a ticket for this or do you have to change the bulb?
    2010 A4 Avant
    Jul 06 2004
    its called the clear corner mod. i was going to do it but i knew in a little while i would just want ecodes, so instead i sold my oem light and bought s4 ecodes. it makes the car look soo much better!
    Veteran Member Four Rings A4Shizl's Avatar
    Jun 11 2004
    2003 Audi 1.8T, 2005 Honda
    Inland Empire
    I had mine done for $100... It took approximately 1 1/2 hours bucause the damb glue would not dry..
    Nevertheless, same look without the cash...
    Veteran Member Four Rings shehatezme's Avatar
    12 BMW F10 528i | 02 Honda S2k
    Bay Area
    I wanted to get this done for a long ass time but no one in the Bay Area is avaliable to do this. OettyBasel is one but I can't get a hold of him. I don't trust myself doing this.
    Jun 11 2004
    Inland Empire
    that's why I had someone do it for me.... just did not trust myself...
    Veteran Member Four Rings bigshrimpin's Avatar
    Aug 14 2004
    S550 AMG, Q5 S-Line, Ultrasport 1.8T
    dammit... i need somebody to do this mod for me as well... i'll pay them to do it
