Hi, I copied the following from someone here's previous post and since my brakes shimmy under hard braking I thought I'd give it a try, but don't know if I should attempt myself or have someone else put these on: Thanks in advance and Here's the post I copied:
"Assuming you are on stock rotors, pads and such? The best stop for your buck, is some stainless steel lines, EBC Greenstuff pads, (or something comparable) and some slotted OEM size rotors. Front and back, then flush out your brake fluid with some fresh stuff. No need to spend big bucks on a big brake kit. Unless thats what you want? The above setup will give you a huge improvement over stock.
You can get everything I mentioned from ECS, except the pads I think. You can get those at AMS, http://www.advancedmotorsport.com/pr...+++EBC+DP31348
This is the setup I have, but haven't even got to run it yet, since my car is undergoing stage 3- upgrades at the same time,, and I haven't got the engine near back together. "
