Results 1 to 27 of 27
Thread: To Hot?
    Registered Member Three Rings
    Jul 13 2004
    san diego
    To Hot?
    well today i was showing a friend my boost gauge install after a 10-15 min drive and it was night and i noticed the turbo area was glowing red...and i mean like crazy red...ive never really seen it like that before and when i was putting my hand near my intake it was 100% hot air....well i kno no1 here cept a few us like the evoms air induction kit but i do own it and i was wondering 2 things....first off- is it normal for it to be that red...and second i need ideas for heat shielding to get rid of some of the heat going to my intake......i kno some y'all have done it so any imput/pics would be great....thanks
    one point eight tee
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Re: To Hot?
    What are you boosting at? I've heard that the KO3 glows after hard runs. The OEM airbox is the best you can do. Maybe add some more heatshielding around the turbo? But then again your turbo would heat up like crazy and get heatsoaked.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    Jul 13 2004
    san diego
    well im runnin the k04 if that means anythin...but the evoms came with a small heat sheild...but i doubt it does anything
    but what kind of stuff would i need to make better shielding
    one point eight tee
    1999 A4 1.8TQ
    San Jose, Ca
    Turbo glow is normal for any turbo. Yes it does get hot in there. Thats why poeple always say (or should of told you) an intake would rob HP (sucking hot air) instead of any beneficial gain.
    If you want to keep it, get a bunch of aluminum foil and wrap that sucker up :)
    Registered Member Three Rings excursion's Avatar
    Feb 20 2004
    Audi
    Lincolnshire, GB
    Perfectly normal with the very restrictive stock manifold
    Veteran Member Four Rings littlewhite's Avatar
    PNW Rainy States
    I have an Evo MS intake, but i added alot of heatshield and DYI air box to cover things up in there. It stays cool if u hop out and open the hood right away after u stop, but when u sit for a bit and open the hood and check, it is still warm due to the fact that warm air is blow in the engine area by the fan. YOu have a pix of your intake? I want to see how yours is looking
    Littlewhite
    Jul 13 2004
    san diego
    yeah i can take one when i get home from work today...what kind or stuff did you use to sheild it? and do you have pics
    one point eight tee
    Veteran Member Four Rings skene's Avatar
    Feb 13 2004
    Las Vegas
    did you use the stock airbox metal heatshield?
    You are supposed to attach that to the EVO heatshield.
    It's a turbo though... using exhaust gases to spin the turbine... of course it's going to glow when it's hot... all metal glows when it hits certain temperatures.
    2017 Toyota 86
    Feb 13 2004
    <> Posts: 9913
    Re: To Hot?
    If I were you I'd ditch that intake kit. I don't care how much heat shielding you use, you will always be drawing the warm air from under the hood. Like JMG mentioned, the stock setup is ideal.
    Now if you're running a much larger turbo (more than a K04) then I'd guess a cone is justified, routed away from the heat.
    -Theodore Roosevelt, 1907
    Jul 13 2004
    san diego
    theres gotta be someway to get it to work better.....heat shield tapes...a thicker shield....ram air directly to the cone
    i dont wanna sound flame but i love the sound of my intake and i love turning heads when drivin by....or havin all the ricer kids jaws drop an stuff like that
    one point eight tee
    Feb 13 2004
    Las Vegas
    ummmmm... poor excuse.... cause when is it sucking in air from the engine?
    at idle...... ooooooooo big performance losses there.
    When you are moving the intake isnt taking in any hot air.
    2017 Toyota 86
    Registered Member Three Rings sighpost's Avatar
    Jul 16 2004
    1999 Audi A4
    Jacksonville N.C.
    I used dryer vent duct to direct the cool air from the ground (lower front bumper pass side) up the filter than I covered the filter with a big aluminum box.
    Here is the DIY link
    And for those of you wondering, yes there is a shield going in between the turbo and the filter. It goes all the way to the frame mount.
    Neuspeed P-Chip 1.0 Bar(5 Bar FPR)::Greddy Full Auto Turbo Timer::GFB DV::HKS Intake::Yellow Konis and Neuspeed Race Springs
    Jul 13 2004
    san diego
    BLAH
    one point eight tee
    Jul 16 2004
    1999 Audi A4
    Jacksonville N.C.
    BLAH?
    Jul 13 2004
    san diego
    i was juss searching old threds for more on heat shielding an y'all have seen this but im newer so i didnt
    http://forums.audiworld.com/a4gen2/msgs/585947.phtml
    ^i could definitly do something like that or what sighpost had done above and then also do what kurzer had posted a while back
    http://audi12v.home.comcast.net/caivs.html
    i dunno...i like it for sum reason and i wanna do sumthin to make it just as good as stock or if possible a little better
    one point eight tee
    Jul 13 2004
    san diego
    haha nah that wasnt to your post....it was to skene's
    one point eight tee
    Jul 16 2004
    1999 Audi A4
    Jacksonville N.C.
    That second link has a cool little bumper vent for the ram air intake. I think I am gonna add taht to my project. I also think Im gonna wrap the air hose going to the turbo in insulation.
    Jul 13 2004
    san diego
    skene- theres a good chance im wrong but when u give it gas then let off isnt it the air echo'n through the piping.......thats what it sounds like to me
    one point eight tee
    Veteran Member Four Rings Devious27t's Avatar
    Mar 02 2004
    2001.5 S4 Avant on Corn
    Orange County
    Re: Re: To Hot?
    turbos dont get heat soaked, intercoolers do. any turbo after beating the shit out of it will glow red that is just what happens when hot air exiting a hot engine causes friction with the walls of the exhaust housing. pm jeff (that is his handle on here) he drives a B6 but managed to make him self a sick heatshield maybe he can show you some pics or point you in the right direction about making one like his.
    oh and iirc he is running the GIAC chip which boost at 1.3-1.5 bar.
    Veteran Member Four Rings bOOOOstedAudi's Avatar
    May 27 2004
    C6 A6 S-line 3.0T Quattro, BT B7 A4 2.0T S-line Quattro
    Sacramento, CA
    look at my sig. that glow is realy with a few effects
    PNW Rainy States
    YES, alot of ppl forget to put that metal stock heatshield back on the Evo one
    Littlewhite
    Jul 13 2004
    san diego
    well i did some heatshielding and ill take pics today an post em
    one point eight tee
    PNW Rainy States
    Sure, that will be great. I need to do somemore shielding and probably have a duct coming up from S4 bumper when i put the new bumper on
    Littlewhite
    Mar 02 2004
    Orange County
    Re: Re: To Hot?
    screw that i wish i still had my stock air box on mine... i wonder if a stock S4 airbox would work with a little customizing?
    Feb 13 2004
    <> Posts: 9913
    Re: Re: Re: To Hot?
    Does that mean you agree with me? I'm confused. I was saying that the stock air box is best (just to clarify).
    I think the S4 air box is similar if not the same as the A4. Same concept at least. I think the S4 may share the same airbox found in the 2.8.
    I so tired of these air intake threads. On a 1.8T, it's all a big waste of time, money, and possibly performance if you take out the stock box.
    But, on a 2.8 I would venture to say there may be an advantage to running an open air element.
    Mar 02 2004
    Orange County
    Re: Re: Re: Re: To Hot?
    yes i agree with you about the stock airbox i have one of those "larger turbo setups" you said that might justify having an intake and i still dont want the damn thing on there like i have right now. about the 2.8 the MAF housing/intake hose on an S4 is 3" which is not the case on the 2.8.
    i agree completely with you on the intake thing, i could see the 2.8 as there might now be as much heat in that area i am just not so sure about the airflow to it . imho intake would only work well if the person had their headlight removed
    Established Member Two Rings Numbersix's Avatar
    Aug 06 2004
    Unless you can get the intake a decent distance away from the hot side of the turbo and manifold, I don't understand why anyone would do an open element filter.
    It's just begging for heatsoak, especially in aggressive stop and go driving. If you just do freeway driving or high-speed canyon runs, especially when the ambient temps are below 70 deg F? Great.
    Otherwise, the stock 'box is very well designed to shield from heat, and protects the MAF from getting damaged by the oil that is on most cotton or foam filters.
    ...be seeing you.
    bucket
