Results 1 to 7 of 7
    Veteran Member Four Rings giago's Avatar
    Feb 12 2004
    audi a4 1.8t 2002
    Mexico
    What is the difference between some springs for fwd or quattro?
    Would some fwd fit to a quattro??
    Is the spring rate different?
    Feb 10 2004
    2019 Mk7.5 Golf R His/Her
    Eastvale
    front and rear suspension is the same so the springs for all intent and purpose should work I'm not sure if the spring rates are the same because on my avant the H&R c/o's are the same for sedan and avant
    Instagram: @daohaus_garage
    PureMS.com
    The rear spring rates are different between the two cars, at least for OE springs.
    Aftermarket springs which are typically stiffer start to blue the difference, as the stiffer you make them, the less they need to be different.
    So while FWD and Quattro springs have identical mounting pieces, depending on the spring, they may or may not provide the proper look and ride height.
    Veteran Member Four Rings fongaroos's Avatar
    Feb 12 2004
    cali
    i think the difference is about 200 lbs to compensate for the quattro system...
    Registered Member Two Rings
    Apr 01 2004
    CA
    The springs are 100% interchangeable as long as they are both from a sedan and have the same engine .
    For example a 2003 A4 1.8t with a sport package the FWD and the quattro have the same paint marks and part number front to back
    Veteran Member Four Rings zemun2's Avatar
    Feb 20 2004
    '04 A4 1.8t FWD APR Tuned
    Zemun, Serbia.
    Are the sport shocks for both FWD and Quattro the same?
    APR Tuned Serbia
    Authorized APR Distributor
    Jul 21 2004
    South Florida
    THey are the same fitment, but they are not the same spring rates. Most people enjoy the look of a quattro spring on a FWD car as it seems to add a little forward rake and actually make the rear of the car sit nice and even (due to the quattro springs being tuned for a heavier ass end). cheers! Mike
    2018 Audi S5
    Gone-
