Results 1 to 7 of 7
    Registered Member Two Rings
    Aug 04 2004
    newport beach CA
    Will a B5 FMIC fit a B6 body???
    Im interested in getting a greddy FMIC from a friend but he got it for a B5 model. I was wondering if anyone knew if it would fit the B6.
    Veteran Member Four Rings hyperspeed's Avatar
    Feb 13 2004
    Chino Hills, CA
    it would require custom piping
    santa monica CA
    I'm not real familiar with the B5 models...but what's the big difference? I'm sure if we got the piping, it couldn't be TOO much different right? afterall, same engine..and stuf..no?
    Feb 13 2004
    Chino Hills, CA
    actually fred u can get a spearco core and fit it.. someone on AZ from hawaii did it..didnt look too good but he did it.
    put it behind rieger
    Aug 04 2004
    newport beach CA
    hmmm i was actually gonna run it on a stock bumper. Maybe remove the bottom grills. The ecode intercooler is too small. heh
    Veteran Member Four Rings Devious27t's Avatar
    Mar 02 2004
    2001.5 S4 Avant on Corn
    Orange County
    its not the piping that is the problem. the problem is like we talked about at the KK gtg that the intake temp sensor is different and wouldnt bolt into the bung on the core so you would have to get one custom made i am sure that they piping would route. you would be amazed how changing the angle here and changing the angle there can make something fit. i speak from experience with the greddy kit. i custom mounted mine also which means i did not use the supplied brackets.
    Mar 02 2004
    Orange County
    haha i hope you have a dremel or some kind of cutting tool cause that bastard wont fit behind a stock bumper. that is the only reason that my car does not have a stocker on it because the damn FMIC wouldnt fit.
