I need help with VAG-COM log reading. I'm monitoring blocks # 003,020,117.
From my understanding block 003 is
-RPM
-Air mass I was told good range is from 187-190 g/s
-Throttle valve angle (Potentiometer)
-Ignition angle (actual)
why am I getting so high numbers on ignition angle?
Block 020
-Ignition angle retard Cyl. 1
-Ignition angle retard Cyl. 2
-Ignition angle retard Cyl. 3
-Ignition angle retard Cyl. 4
I was told they should not exceed 3-5.
Why am I showing diff reading on all 4 cyl.? (8.3-3-6-8.3)
You can check the .csv file here
http://f1.pg.briefcase.yahoo.com/bc/...=/Audi&.view=l
TIA
Dejan
