Hi Diesel'S4 and welcome on board.
I just installed my S4 Xenon ecodes to my A4, see the thread:
http://www.audizine.com/forum/showth...threadid=16564
The installation is pretty straight forward: 4 screws (torx, T30) holding each housing. Remove the upper screws, but keep the lower screws attached, just loosen up them (you'll need a long screw driver for those). Pop out the wire socket with a screw driver head and unplug the other cable hook.
Then just pull those housings in one piece and replace the high beam bulbs and turn signal bulbs from your stock housings. For the HID unit, you need to remove 6 small torx screws from the behind of the housing.
After you've done the bulb changing just push the housings in appropriately and you're done.
REMEMBER THIS:
Use duck tape (or marker or what ever) to "save" the figure of your stock Xenon beams before removing the housing. This will be a great help when re-aligning the lights afterwards. I made a mark of the figure from 1ft distance and 25ft distance. And note that the Euro spec figure is slightly different than the US.
Good luck
Originally posted by Diesel'S4
i hope to learn alot from the alum here...
anyone know where there is a how to on removing the headlamps on the B6...? I've got a set of Euro Xenon+ coming in the next few days, and would like to tackle the install myself...
