Originally posted by rhythmboy
Hi,
I'm new to this forum, and new to my 2001 S4. Just picked it up recently, and brought it to my local dealer to do their "Audi Assurance" 150-point inspection. (Whether that's worth it or not is another story.) AFAIK the car is stock, it's fresh off a lease. I bought it at a lower price, thinking if anything was wrong it was upgrade time.
The dealer mentioned I need a few things replaced - a rear caliper (485), rear pads & rotors (200), and front rotors (485). Also a lower control arm bushing was torn (450). Their price, including labor is about $1600
My question is - are there performance upgrades that I should consider, rather than buying stock from the dealer?
The research I did brought me to brake upgrades - Brembo and StopTech - but it seems I'm spending somewhere in the $6k range in parts that way.
I didn't really find anything for an upper control arm.
I'd rather keep it close to the price range, but would probably spend an extra $1000 or so if it was a worthwhile upgrade.
Any ideas?
Thanks in advance for your help!
Rhythm,
Congrats on the new purchase! You'll definitely have fun with it.
Is your car a street car only or will it see the track(road course) a few times a year?
There are obviously numerous brake upgrades available---all the way up to STaSIS 14"/6pot kits at $3595. But of course if you're looking for more of a budget upgrade and your S4 will be primarily street driven, then I'd highly recommend STaSIS' XDR front Alcon rotor upgrade. Yes, they are a bit more money up front vs stock rotors, but with spirited driving will come plenty of front stock rotor failures. And because of that, I'd suggest doing it right the first time with STaSIS' components;
-STaSIS Street Sport XDR Front Rotor Kit for S4/S6/A6/Allroad; 2 Alcon (321 x 30mm) directionally vented/heat treated/segmented gas slotted 2pc floating rotors, 2 STaSIS directionally vented rotor mounting hats
$895/set
(For reference, here is a stock rotor;
-12.6"(321x30mm) Zimmerman solid front brake rotor for '00+S4
$138.85/each)
Regarding pads, our clients have loved the Hawk offerings. The Hawk HPS's dust less than stock, stop much better, and are quieter than stock.
Hawk HPS (street) front pad set for B5 S4/A6
$128.20/set
For rear brakes, we haven't seen any issues with stock rear rotors and a high quality rear pad set like the Hawk HPS's;
10.1" Rear ATE factory solid rotor for '00+ S4;
$64/each
Hawk HPS (street) rear pad set for B5 S4
$61/set
On the rear caliper there is no simple/economic upgrade is available. A new caliper lists for about $119 and shouldn't be any more than 1hr to R&R. They'll need to do a brake bleed afterwards which is another hour as well. But $450 sounds a bit high for that. I'd recommend finding a good local independent shop to take it to.
The lower control arm bushing (again, no performance upgrade) is really common---we see those all the time. You should do the other lower one as well while you're there. A lower control arm is $247.85 and labor is about 1.2hrs for each(a little less if you do both at one time).
If you need any parts, even stock parts, let me know. We have no sales tax in Oregon(a considerable savings) and offer same day shipping on most factory parts.
Sorry for the monologue but I hope the info helps.
If you have any other questions, feel free to ask--I am always happy to help!
Best,
Jeremy
