Results 1 to 12 of 12
Thread: Help!
    Registered Member Three Rings ImpalorA4's Avatar
    Mar 15 2004
    AhhFOUR
    Question Help!
    I have a 96 and i just got the 2piece projectors. I looked at the connectors and they are a little different. I was told that its plug and play but is it? do i need a new harness?
    Also the metal rods that look like thay are holding the projector in place! Do i need to take them off?
    Alright thanks for your help.
    Veteran Member Four Rings skene's Avatar
    Feb 13 2004
    Las Vegas
    huh? what? can you better explain?
    do you have the round connectors from factory?
    if you do then yes you do have to get a new harness.
    2017 Toyota 86
    Feb 13 2004
    <> Posts: 9913
    What kind did you order? Are they Valeos? If so, they then you'll need the adapter. I think ECStuning.com sells them.
    Yes, take those metal rods out, assuming you mean those weird things that they pack them in to keep the eletrical parts from getting knocked around during shipping.
    -Theodore Roosevelt, 1907
    Mar 15 2004
    AhhFOUR
    Well the connector on the old Headlight is round and has three prongs and like there is this plastic thing in the middle. I think its just to guide the connector into the correct spot. The new one are 2piece Ecodes that i bough from motion garage .They dont have the platic pice in between the prongs. And the prongs are set up a lil differently. Im gone try and connect them and see if it works. If not then ill get the adaptor.
    Skene you sound mad! :]
    Veeelad is my name
    DG - 06 G35 COUPE :)
    Ibis 07 A4 TQM Ti NAV+ on order WAAAWAAAWEEEWEEE
    Feb 13 2004
    Las Vegas
    nope not at all.
    2017 Toyota 86
    Registered Member Four Rings
    Aug 08 2004
    00' VW GTi
    Is that you in your Sig Skene? I've always wondered who that is....
    -www.eurotunedcomposites.com-
    http://i2.photobucket.com/albums/y16.../signight1.jpg
    -STS Auto-X
    Feb 13 2004
    Las Vegas
    David Copperfield....
    2017 Toyota 86
    Mar 15 2004
    AhhFOUR
    Originally posted by skene
    nope not at all.
    good
    Feb 13 2004
    <> Posts: 9913
    What's Motion Garage? Do they have a website? I checked but didn't find one.
    Mar 15 2004
    AhhFOUR
    Here is the thread that they ran the GB for these
    http://www.audizine.com/forum/showth...threadid=14008
    also i meant to say Emotion Garage. Sorry
    Veeelad is my name
    Aug 08 2004
    00' VW GTi
    Hahahah wow. Way off.
    -STS Auto-X
    Feb 13 2004
    <> Posts: 9913
    Ok, those are Depots. They should plug right in with no wiring kit needed.
