Results 1 to 11 of 11
    Veteran Member Four Rings audidood's Avatar
    56 Oval, 2017 Tacoma
    san diego, ca
    what turbo is in the evo?
    what turbo is in the Evolution? why is it that their 4-banger gets 270+ hp and our audis get 170?
    2004.5 USP A4 1.8t with mild mods.
    1956 VW Bug with major mods.
    Veteran Member Four Rings shehatezme's Avatar
    12 BMW F10 528i | 02 Honda S2k
    Bay Area
    One that's bigger than ours.
    Registered Member Four Rings G_A4's Avatar
    Jun 04 2004
    Audi A4 1.8T 2004
    Waianae, HI/NorCal
    Re: what turbo is in the evo?
    that's a good question. the car comes with a FMIC too.
    Veteran Member Three Rings AWDTurboLuvr's Avatar
    Apr 21 2004
    A4
    Vancouver
    First of all, it's a 2.0L engine versus 1.8L and the Mitsu is designated as the 4G63 with a Mitsubishi 16G turbo. Oh yea, it's also bigger than ours and they have a few more larger turbos that directly bolt onto this motor as well. The 16G turbo has 2 variations...the smaller one can make 350-375hp, the larger one (bigger compressor section) can make 400hp but at the expense of less boost at lower rpms.
    2003 A4 1.8T Quattro - [B5 S4 Brakes.SS lines.PBR pads] [SB OFE STG3 Clutch] [S4 RSB] [BBS CH 18"] [Falken 452] [CC MOD]
    2002 Mini Cooper S - RMW Tuned 191whp/168 lb-ft [Dinan S1] [JCW injectors] [JIC/Cross inverted coilovers] [TSW LCA] [Alta 15%] [GramLights Optomise57] [Dunlop Direzza Star Spec 215/45/17] [ProSport Boost Volt Gauge]
    Registered Member Two Rings Diesel'S4's Avatar
    Aug 07 2004
    '04 S4
    PA
    16G... also a twin scroll, which allows for very fast spooling and decreases lag, but it is still present...
    the A4 was not meant to do what the Evo does, hence the big separation in performance of the two...
    you could always slap on a bigger turbo...
    Jun 04 2004
    Audi A4 1.8T 2004
    Waianae, HI/NorCal
    theirs a marginal difference in price from the EVO and the A4.
    Audi A4 1.8T
    GT2871R REVO
    [email protected] Race gas
    13.4@103MPH 91 Craptane
    HARDCORE
    Feb 12 2004
    99.5 1.8T A4
    Cleveland OH
    also the evo runs at like 19lbs of boost!....and thats stock!
    Veteran Member Three Rings voodooA4's Avatar
    also, if they made the A4 with a larger turbo (stock) and higher boost...it'd be encroaching on S4 territory...
    98.5 Cactus Green A4 Quattro, APR Chipped
    114K Miles
    Open Source ECU: http://groups.yahoo.com/group/openecu/
    OpenDiag Group: http://groups.yahoo.com/group/opendiag/
    1999 A4 1.8TQ
    San Jose, Ca
    Get yourself one of those EVO turbos and toss it in your ride Gerald.
    The real question is, why don't the WRX and EVO 4WD systems rob wheel HP as much as the Quattro system (is it really the 50/50 distro Quattro uses?).
    Apr 21 2004
    A4
    Vancouver
    Hmmm...I'm not sure about that dukez, the WRX stock has 227 and Turbo dynoed one at 171hp and they considered that high for a stock one. Usually they get only 164hp. Still not as bad as the Quattro but their AWD system is supposedly lighter.
    Aug 07 2004
    '04 S4
    PA
    that's not really accurate as Evo's were only dynoing at about 220ish stock... so they AWD system was robbing Hp... maybe not on the clip the Quattro does, but still more than a conventional 2WD system...
    the Evo has a true 50/50 split as well as the STi, but the STi was selectable up to 70/30 i beleive...
