Results 1 to 3 of 3
    Veteran Member Four Rings A4_Andre's Avatar
    Feb 13 2004
    99.5 Audi A4 2.8Q Tip
    Staten Island, NY
    greasing the sunroof
    how do i do this and what grease should i use? it's starting to make a squeak at times when i flip it up
    Veteran Member Three Rings chrisrunner's Avatar
    Feb 12 2004
    97 A4 1.8t, 2000 BMW 328i
    boston area.
    i used white lithium grease and wd40...both worked great....goddamn squeaky sunroofs
    chris.
    chris.
    http://img.photobucket.com/albums/v9...ri/Driving.gif
    you call it your right. i call it your weakness.
    Veteran Member Four Rings RedRocket's Avatar
    Feb 12 2004
    Toronto GTA
    Before you go on making a mess with WD-40, try silicon. The best way is to get a silicon stick(it looks like chap stick) and do the rails with that. I think that's how it's done at the dealership if I am recalling correctly from the Owner's manuel.
