Results 1 to 4 of 4
    Senior Member Three Rings pearl1.8T's Avatar
    Feb 12 2004
    Audi A4 1.8TQ
    Bay Area, Cali
    Engine questions
    Hey guys, I started my engine today and it wouldn't get out of first. I have an 1.8TQ tip, and in auto mode it wouldn't get out of first, so i switched to tip, and it wouldn't get out of first either. I pulled over, turned off my engine, restarted the car, and same thing. After driving at 10 miles an hour back to my house (I didn't get very far to begin with), i turned my engine off, did the pedal reset thing (turning key to 1st slot position, and holding down the gas), then turned my car on, and it began to shift normally, but my dash was all lit up. The P R N D 4 3 2 bar was all lit, and when i switch to tiptronic, the tiptronic mode doesn't show up on my dash, and tip shifting doesn't work. Coming to a stop also makes the car give a harsh little jerk when it downshifts to first. Has this happened to any1? Anything I can do to fix it, or should i just bring it into the dealership? I have an apr 1.0Bar chip as well, could it be something faulty with the chip? Any help or information would be much appreciated.
    1998.5 A4 1.8TQ [19x8.5 ADR M-classic][P-Zeros][Neuspeed Race][Bilstein sports][K04][GIAC][tip chip][K&N][Hyperboost DV][APR snub mount][RS4 grill][S4 wheel liner][JVC El Kameleon][Rockford Fosgate XLC][MBQuarts][Zimmerman][LLtek fogs][6k HID]
    Veteran Member Four Rings skene's Avatar
    Feb 13 2004
    Las Vegas
    Multifunction switch went bad.
    2017 Toyota 86
    Feb 12 2004
    Audi A4 1.8TQ
    Bay Area, Cali
    thanks for the reply skene. How much does that usually cost to fix? Is it best to just into the dealership?
    Feb 13 2004
    Las Vegas
    its not an expensive part IIRC.... but a PITA to get to.
    It's a switch on the transmission.
    2017 Toyota 86
