Results 1 to 31 of 31
Thread: Turbo Timer
    Registered Member Three Rings AFOUR_PLAY's Avatar
    Apr 15 2004
    Sydney, Australia
    Turbo Timer
    I know this has been done to death.
    I have searched the forums but want to know which TT is the easiest to install and doesn't interfer with the alarm/immobilisor.
    I was thinking of the A'PEX TT but am worried about the handbrake cutout switch causing problems.
    I wasn't going to put a TT but the K03 stopped working and the K04 is going in.
    Thanks
    Daniel
    http://smileys.smileycentral.com/cat/3/3_2_116.gif
    A4 1.8T Quattro - Clicky Here
    -Stoptech Brake lines - RS4 Grille - DIESELGEEK SS - GFB DV - APR Snub Mount - K04 Turbo - Samco Turbo Inlet Hose - S3 injectors - GIAC - 18x8.5 1/16 Carlsson copy 18/40/235
    Veteran Member Four Rings needforspd's Avatar
    Mar 05 2004
    Deceased 01.5 A4 1.8tm
    Sylmar Hills
    Greddy TT, had agravic (Ansen) install it and have no problems w/ it at all
    Do you have a need for speed? Then drive it like you stole it!
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    ditto:
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    May 02 2004
    99.5 1.8tqm
    Flemington, NJ
    i have the blitz fatt tt, real easy install
    4 wheels
    2 headlights
    1 glovebox
    1 ac unit
    1 radio
    1 engine
    Apr 15 2004
    Sydney, Australia
    This one?
    Daniel
    May 02 2004
    99.5 1.8tqm
    Flemington, NJ
    yup, but mine is blac
    4 wheels
    2 headlights
    1 glovebox
    1 ac unit
    1 radio
    1 engine
    Veteran Member Four Rings HotSauce's Avatar
    Jul 26 2004
    Madison
    What's all involved in the installation, now that we're all here.
    Veteran Member Four Rings littlewhite's Avatar
    PNW Rainy States
    Had the APexi auto timer in for couple of yrs b4 i took it out and put an alarm on. Works great, has A/F ratio (didnt hook up), Voltage, timer, and O2 sensor.
    Littlewhite
    May 02 2004
    99.5 1.8tqm
    Flemington, NJ
    check the audiworld tech articles. i liked the one at the bottom.
    4 wheels
    2 headlights
    1 glovebox
    1 ac unit
    1 radio
    1 engine
    Apr 15 2004
    Sydney, Australia
    Did anyone have problems locking the doors with the key fob while the TT was on (engine was running)?
    Daniel
    Registered Member Four Rings Zodiak's Avatar
    Washington DC
    if installed properly the TT will not interfere with the central locking system or the windows. Just follow the write ups on AW
    Registered Member Three Rings sighpost's Avatar
    Jul 16 2004
    1999 Audi A4
    Jacksonville N.C.
    I did follow and still no work
    I thinks its the issue of wiring the blue and black wire from the fuse box. I have the right wire from the box but the wrong one from the ignition sys. It says use the red and black. i did and my windows stopped working so i tried the small red wire and my windows now work but the TT still wont. Then I noticed another red and black wire. Is taht it?
    Neuspeed P-Chip 1.0 Bar(5 Bar FPR)::Greddy Full Auto Turbo Timer::GFB DV::HKS Intake::Yellow Konis and Neuspeed Race Springs
    Washington DC
    my guess would be yes, it's that other red&black wire.
    Jul 16 2004
    1999 Audi A4
    Jacksonville N.C.
    Ill try it tommarow. Good night everyone.
    (Glad I have a ride to work tommarow)
    May 02 2004
    99.5 1.8tqm
    Flemington, NJ
    make sure you ground the purple wire and black wire as well or else the tt wont work. my windows dont work when i take the key out and the turbo timer starts. i thought that was normal and if its not , i just put the windows up b4 i start the timer
    4 wheels
    2 headlights
    1 glovebox
    1 ac unit
    1 radio
    1 engine
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    this happend to me before, infinck is the one that helped me with my problem, if you installed the tt and the windows work now but the timer doesnt. it most likely is and you just need to play with the unit and change around some settings. when i first put this in i realized my windows didnt work, after we got themto work the timer didnt, then i messed with the seting and all of a sudden it works, NOW I DONT MESS WITH THE SETTINGS, im afraid it wont work, ohh and i hope you spliced in the wire for the parking brake, this is a great feature.
    Apr 15 2004
    Sydney, Australia
    has anyone experienced problems locking the doors with the turbo timer running the car?
    Don't want to get a turbo timer if I need to lock the doors with the key or wait for the engine to shut down before locking the doors with the remote.
    Thanks
    Daniel
    Mar 05 2004
    Sylmar Hills
    i lock my doors w/ the remote and the TT counting down w/ no problems at all
    Veteran Member Four Rings Silvant's Avatar
    Feb 12 2004
    Past: 95 Stg3 UrS6 Avant, 01 Stg3 A4 Avant
    LA | CA
    save your money.. you dont need one.
    Mr. Inappropriate Porno Avatar Man.
    " So do us all a HUGE FAVOR silvant...STOP breathing our air..and go kill yourself...you punk POS...."
    Apr 15 2004
    Sydney, Australia
    My K03 went 'cause I didn't let it cool down. Don't want the K04 to do the same.
    Daniel
    Feb 12 2004
    LA | CA
    who told you that was the reason...
    as long as you arent in boost for a bit after a hard drive, you are fine...
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    You don't "really" need a TT. It's a nice little convenience if you are a hard driver like me. I don't like waiting either. IF you have the extra $$$ and don't mind divertign to really helpful mods then do it. I've had no problems with mine at all. No interference with the doors windows alarm etc...
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    Audi B5 A4
    Apr 15 2004
    Sydney, Australia
    My GF lives 40 mins drive (average speed 50mph) from me and trying to explain to her parents when they hear me arrive and open the door for me that I can't come in yet because I have to let the turbo cool down will sound kinda stupid to them.
    Plus i'm lazy and can't be bothered sitting in the car until it cools down.
    TT is worth the extra $100
    So it should not interfere with locking via key fob?
    JMG what TT do you have?
    Daniel
    Veteran Member Four Rings 4ingDrive's Avatar
    Feb 25 2004
    Chi town burbs
    I've got my tt rigged to operate the cooling fan in front of the turbo and cat. If hooked up properly everything will still work normally when the car is running on the tt.
    99.5 A4 Avant
    always some shit broken
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Greddy III. You could still just keep the rpms below 3k for the last 2 minutes of your drive to your G/F's. That is sufficient enough for the turbo to cool.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    Audi B5 A4
    Registered Member Two Rings
    Jun 06 2004
    A4
    Irvine/ San Francisco
    JUST GET a GREDDY III and it will do the job!!!
    Follow the tech page on audiworld and you will figure out how the to intall it. I believe you have to tap into 3 wires, one ground n power (not sure, maybe more).
    TT is not that a "MUST" but not a bad investment. If you got the extra $100 to throw around, why not!
    Marco
    Apr 15 2004
    Sydney, Australia
    I was reading on the B6 forum that they need a turbo timer companion or something. Is that for B6's only?
    Daniel
    Washington DC
    yes, that is for the B6 only
    Apr 15 2004
    Sydney, Australia
    Thanks
    Cool!
    So should have no problems installing this?
    Daniel
    Washington DC
    correct
    Registered Member Two Rings WRX2A4's Avatar
    Sep 20 2004
    2001 Audi A4 1.8T, 2002 Yamaha R6
    St. Louis, MO (Indiana University now)
    Blitz
    I have the Blitz DCII on this car and I had it on my WRX as well. On the WRX I had some problems with the power locks/alarm not working when the TT was on, but there is no issue on this car.
    I say this as I remember that just yesterday the TT stopped working. I assume that it is not connected to the E-break correctly as it will still turn on and read boost, just wont keep the car running. I guess I will be doing the first dis-assembly of my new toy to find the problem.
    Really though, it is a good setup and it is attractive to boot (minus the off green lighting)
    D
