Results 1 to 12 of 12
    Feb 12 2004
    99.5 1.8T A4
    Cleveland OH
    winter performance with Toyo Proxes 4s?
    Thinking about buying Toyo Proxy 4 ultra high performance all-season tires and putting them on my wheels instead of buying winder rims/tires. How do these kind of tires handle in show? Anyone ever use them? The size would be the same as my S03s 225/40/18. Also, how much summer performance would I be sacrificing?
    http://www.toyo.com/tires/tire_lines.../proxes_4.html
    Veteran Member Four Rings Audi_Sniper's Avatar
    01 & 04 Audi A4 1.8t quattro
    Buffalo, New York
    I have them, but I have not run them in the snow,and don't plan on it. I just got them this past May. But they are very good in the rain. I have had no probs at all with them and they seem to be holding up very well.....
    Bringing the Great Lakes Regions Together
    http://www.greatlakeseuros.com
    BetaAlphaTau Member # 30
    The toys:
    01 Audi A4 quattro APR stage III (Fast and tight like some of your little sisters)
    04 Audi A4 quattro (Der neue tägliche Treiber)
    Feb 12 2004
    99.5 1.8T A4
    Cleveland OH
    I'd get smaller winter whels/tires but I have a problem. With anything smaller then 18 I won't make it up the driveway as the car will be too low. Right now thre is a 1/2" gat when I get off the driveway ricer style!.........and thats without any snow or ice.
    Veteran Member Four Rings D Piddy's Avatar
    Feb 12 2004
    Me: 2010 B8 A4 S-Line In the Family: BMW Z4M, BMW 335xi, Range Rover Evoque, Honda Element
    Washington, D.C.
    smaller wheels should make no difference in ride height. drivin on 18s in the winter's craziness in my book. buy cheap 16s, get winter specific tires, use yur quattro and yu'll be fiinneee. my driveway sux a lot and i have no problems at all with 16s, tire diameter should be the same
    Feb 12 2004
    99.5 1.8T A4
    Cleveland OH
    with 16s or 17s the car will sit a lot lower with race suspension! With 16s it will drop over 1" which I don't have
    Buffalo, New York
    Yeah your right. When I put my winter wheels on my car is real low.... Thats why I'm looking for CO's.....
    The toys:
    Veteran Member Four Rings Burntaudi's Avatar
    Sold:1997 Audi A4
    Maplewood, Minnesota
    As long as you have the correct size tire 16's should be the same height & diameter.
    Alex
    Sold 97 Audi A4 Turbo Quattro Manual
    KO4/GIAC PC-16/GHL Exhaust/EVO FMIC/ Southbend Clutch/JHM Short Shifter & Linkage/Shifter Bushing/Koni Coilovers/Neuspeed Sways/17" OZ Superellegras/Ecode Headlights/VVME Hids
    Current ride 03 Tahoe Z71
    Feb 12 2004
    99.5 1.8T A4
    Cleveland OH
    There is no way they will be the same diameter on the car as th tires will compress more. I've done it and know for sure. The outer diameter of the wheel/tire will be the same off the car.
    Sold:1997 Audi A4
    I guess I could see that...never thought about sidewall flex.
    Alex
    Veteran Member Three Rings chrisrunner's Avatar
    Feb 12 2004
    97 A4 1.8t, 2000 BMW 328i
    boston area.
    i just got them on my audi a4....these same toyo's have been on the bmw 328i since i got the car....theyve been flawless in intermittent weather and i would highly suggest them....hence why i bought them for the a4.
    chris.
    chris.
    http://img.photobucket.com/albums/v9...ri/Driving.gif
    you call it your right. i call it your weakness.
    Feb 12 2004
    Washington, D.C.
    just put more air in and there shoudn't be an issue with ride height. i guess it would be a tad but lower, but it shouldn't be an inch drop. but i guess u would know better than me, so it's yur choice. personally, i'd spring for full snows, that way u pay for 4 tires, instead of a new car should u crash in the snow
    Veteran Member Four Rings Chard's Avatar
    Not so sure it's completely due to the sidewall flex, but the difference in wheel sizes makes a difference in the overall diameter, even when going with a taller sidewall. For instance, a 235/35/19 tire is taller than a 225/45/17. I run 19's and when they're standing next to my spare S4 wheel, the diameter is a lot longer, on and off the car.
    Plus, when I run my autoX setup, my 205/55/16s make my car sit a LOT lower than with the 19's on.
