Results 1 to 19 of 19
    Established Member Three Rings A Foore's Avatar
    Apr 07 2004
    '05 6spd TSX with NAVI.
    GO LEAFS GO! GO LEAFS GO! ...
    a lot of smoke at startup...
    I've mentioned this a while back, but have no answers and I found something else interesting about my situation. Well, here's the briefing.
    For the last few months (all of summer), I've noticed a lot of smoke coming from my tail pipe when I start my car. This only happens intermittently and when it does happen, it's usually after the car has been sitting for at least a few hours. Usually the next morning. There would be a lot of smoke, then after about 30 seconds to a minute, the smoke would be all clear. What I've noticed is, when I step on the gas while there's smoke, it would "puff" the smoke out quicker. Another thing I've noticed is when I turn up the fan in my car, there would also be more smoke. Either way, after about a minute, all the smoke is clear and it's all fine. No CEL, hesitation or anything. I just find it kinda odd.
    No, it's not burning oil. The smoke is not blue, but kind of like a greyish/white. And I dont think it's leaking coolant, cuz if it was then I would have had to top up the coolant already, which I haven't cuz it's full.
    Actually, now that I think about it, it may have started right after I changed my plugs, but I don't see why plugs would cause that to happen.
    So....any ideas what may be causing this?
    Sorry for the long message.
    Thanks.
    97 1.8TQ
    GIAC / 710N / H&R Race / Koni yellows
    Feb 10 2004
    2009 A4 2.0T Sedan
    Did you check all of your hoses? That's where I'd start.
    Apr 07 2004
    If there was a leak in a hose, then wouldn't I get a CEL light since it's been like this the whole summer?
    97 1.8TQ
    Feb 13 2004
    <> Posts: 9913
    No, you won't always get CELs unless it trips a code.
    The type of smoke you're describing sounds like it's due water/coolant leaking into your system. If it's happening frequently and it can't be written off as condensation here and there, then I'd say you have a leak somewhere.
    One common problem this indicates is the head gasket.
    Have you noticed your coolant level go down at all?
    -Theodore Roosevelt, 1907
    Veteran Member Four Rings Burntaudi's Avatar
    Sold:1997 Audi A4
    Maplewood, Minnesota
    Sounds like a leaky fuel injector. If you had a leaking fuel injector it would drip into one of the cylinders. When you start the car it's gonna take a minute to burn off the extra fuel once it does the exhaust is gonna clear up.
    Does it run rough till it clears up?
    Alex
    Sold 97 Audi A4 Turbo Quattro Manual
    KO4/GIAC PC-16/GHL Exhaust/EVO FMIC/ Southbend Clutch/JHM Short Shifter & Linkage/Shifter Bushing/Koni Coilovers/Neuspeed Sways/17" OZ Superellegras/Ecode Headlights/VVME Hids
    Current ride 03 Tahoe Z71
    Apr 07 2004
    Nope, coolant level hasn't gone down. If it's a leak somewhere, then wouldn't it always happen rather than just intermittently?
    I never tried running it while it was smoking. I just wait til the smoke goes away before I drive. If it is a leaky fuel injector, then would it smell like fuel when the smoke comes out?
    97 1.8TQ
    Sold:1997 Audi A4
    Yep it's gonna smell like gas if your burning off extra fuel.
    Alex
    Veteran Member Three Rings voodooA4's Avatar
    if the smoke smells sweet, then it's probably coolant. don't inhale too much though...
    98.5 Cactus Green A4 Quattro, APR Chipped
    114K Miles
    Open Source ECU: http://groups.yahoo.com/group/openecu/
    OpenDiag Group: http://groups.yahoo.com/group/opendiag/
    Apr 07 2004
    Seems like a few people have mentioned coolant. If my resovoir (sp) is full, then where is the coolant leaking from?
    97 1.8TQ
    Awaiting Confirmation Four Rings
    Feb 12 2004
    Albany NY
    I didnt read your whole post b/c im exhausted. But , when my car was doing that, it was the sign of the turbo going bye bye's.
    Veteran Member Four Rings bitterchild's Avatar
    Feb 16 2004
    audi is chit
    you have to diagnose the smoke as either fuel, coolant or engine oil. If its oil, mechanically its likely your valve stem seals
    concours show prep in the DC metro area
    turbos, rods, pistons, clutches, etc.
    Apr 07 2004
    I alreadly mentioned that in my post
    97 1.8TQ
    Apr 07 2004
    If I am burning engine oil, then the smoke will be blueish, correct? Also, if it is engine oil, wouldn't the smoke be constant rather then just at start up?
    97 1.8TQ
    Feb 13 2004
    <> Posts: 9913
    I don't see where you mention it in your post.
    We still don't know if it's coolant, or fuel causing the smoke. You can rule out oil if it's not blue/black smoke.
    It could be a small coolant leak, that pools up a bit when the car sits, hence the smoke at start-up. After that it may not smoke much after it burns off.
    So after you drive the car for bit, then stop and let it idle, you don't see the smoke at all anymore? If not, then I would check what burntaudi said above.
    Apr 07 2004
    I did rule out burning oil since it's not black/blue. I
    have tried stoping and idling for a bit and no, there is no smoke.
    I guess this issue would lean more towards what burntaudi said regarding the fuel. I haven't smelled the smoke yet, but I will the next time this happens.
    97 1.8TQ
    Veteran Member Four Rings Devious27t's Avatar
    Mar 02 2004
    2001.5 S4 Avant on Corn
    Orange County
    iirc unburnt fuel comes out black not white. the water jackets on his turbo could be on its way out. that would not throw a code. sounds like someone didnt cool the turbo properly...
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    when my bypas valve hose blew off and car was running rich black smoke was comming off so if your smoke is black then its possible its an injector leak but i doubt that it is if you say the smoke is grey. if its grey i want to lean that its more on the coolant side but i never had this problem before. i just hope its not the turbo going out. knock wood.
    Apr 07 2004
    Water jackets? Sorry, I'm still pretty new to turbos. If it is the water jackets, then will the turbo need replacing or is that part you're referring to replaceable?
    As for cooling the turbo, I think I cool it properly. When ever I drive hard before my destination, I open up the door a bit for the door open chime and I shut the car off when the chiming stops. Otherwise I drive normally a few blocks before my destination.
    If it is the coolant, then wouldn't I have had to top up the coolant by now? It's been happening since beginning of summer.
    97 1.8TQ
    Feb 13 2004
    Lakewood, CA
    no not realy, even tho your coolant is correct it doesnt mean you have a big leak, like you said its only for a little bit at the starts and that it doesnt happen all the time, if you said it happens all the time when you drive then i can see how you will see a noticable difference in lost fluid but if it only hapens once in a while and not very long then it still is a possibility,
