Page 68 of 70 FirstFirst ... 18586667686970 LastLast
Results 2,681 to 2,720 of 2784
  1. #2681
    Feb 02 2017
    Beaverton, OR
    Any recommendations on a good sealant/wax?
  2. #2682
    Veteran Member Four Rings AllroadCorbin's Avatar
    Jan 15 2014
    B5 S4 (sold) | Saab 9-3 | B8.5 Allroad (sold) |B9 Allroad (totaled) | LB7 Duramax
    Boston, MA
    Quote Originally Posted by chip_ View Post
    Dr. Beasleys ceramic nano resin. Shit is nuts
    B8.5 Allroad | APR | CTS K04 - SOLD
    B9 Allroad
    B5 S4 | GermanElite | SRM K24
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  3. #2683
    Feb 02 2017
    Beaverton, OR
    Quote Originally Posted by AllroadCorbin View Post
    Interesting stuff and hadn't heard of before.
  4. #2684
  5. #2685
    May 21 2017
    Phoenix
    What's the best way to clean and protect a 2014 S5 Cabrio top? First time owning a ragtop... Right now water just saturated the top (not to the interior, just doesn't repel well) / no water beading, etc.
    Sent from my iPhone using Tapatalk Pro
  6. #2686
    Stage 3 Forum Advertiser Four Rings DetailersDomain's Avatar
    Feb 23 2004
    sure thing if the top is relatively new I would use your car wash and use a nice brush like this one on top of it, gently brush, let dry and protect with Nanolex Convertible Top Sealant
  7. #2687
    Feb 02 2017
    Beaverton, OR
    Is there a preference on the Nanoskin sponge or wash mitt on which one works better/easier to use?
  8. #2688
    Feb 23 2004
    I like the sponges better.
  9. #2689
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    Hello, I am hoping you can help me with two questions:
    * I have a large raised spot on my Magma Fine Nappa leather seats, which is also a bit firmer/harder than the surrounding leather. Since it is about the shape and size of my daughter's backside, I anticipate it was caused by either her sweat after a cross country meet or something on the grass that she sat on at the meet. I have used Lexol leather conditioner on it with little to no effect (it did very slightly lessen the "clothing stitching" marks present around the border of the spot. Could you please advise how to get rid of the spot?
    * Can you please advise whether there is any way to determine whether a car has a nano coating/finish (i.e. Quartz Pro, etc.) on it? I purchased my car used from a dealership and want to properly maintain the finish, which is incredible. From what I read nano coatings need to be maintained differently from standard clear coat finishes.
    Your advice is appreciated. Thanks.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
  10. #2690
    Sep 14 2013
    New Jersey
    Hi Philip,
    I just brought an used 2014 S7 wanted to know what you guys charge for a full detail?
    Thanks
    j
    2014 S7 Moonlight Blue Metallic | Bang & Olufsen | Comfort Seating Package | LED headlight | Cold weather package
    2014 S4 Premium Plus | ESTORIL BLUE CRYSTAL EFFECT | RIP 2017
  11. #2691
    Feb 23 2004
    if you can please email me
  12. #2692
    Sep 14 2013
    New Jersey
    Email sent earlier today
    Thanks
    J
  13. #2693
  14. #2694
    Veteran Member Three Rings nicotino15's Avatar
    Jul 24 2011
    2016 Q5 3.0T
    DFW, TX
    anybody know the best product to use on these wheels for protection? I think coating them might not be best due to the nature of material:
  15. #2695
    Mar 08 2013
    2013 RS5 Cab / 2015 Q7
    Southern Illinois
    Quote Originally Posted by nicotino15 View Post
    What do U mean by “the nature of the material”? Is this some kind of new material used for the wheels? If not & if it’s a standard Audi factory wheel, the normal “Wheel Sealants” would/should be more than adequate. Gyeon (purchased from DD & it works spectacularly) or some other type of sealant designed specifically for wheels d/t the temperatures that develop. Sonax also makes a spray on wheel sealant “Rim Shield” which also works pretty well but only for 4-6 weeks. After that needs to be re-applied. Check out DD videos regarding you question/topic, or YouTube works well for additional viewing. NO affiliation w/DD, just an excellent vendor/sponsor & tier 1 products, you can’t go wrong w/them.
  16. #2696
    Feb 02 2017
    Beaverton, OR
    What part is needed to do the following -
    I have a gun similiar to this - https://www.homedepot.com/p/Briggs-S...4312/206278503
    I want to add this to the end of the hose https://www.amazon.com/dp/B01CE78VO8...=311OH0D7OG2BZ
    What connector piece do I need to make this happen?
  17. #2697
    Mar 08 2013
    Southern Illinois
    Model #AP31037B, @ Home Depot. It’s a male/female Quick Connect coupler(s)for pressure washers. Important to get the couplers rated for the “Pressure Washers” & NOT the ones designed for a garden hose. U may want to just take the part(s) to the HD & attach the couplers to make sure they fit that way no worries. Additionally, U may want to think ~ getting a coupler for the bottom end of the PW gun, makes it easier to wind the hose up w/o the gun attached. If U have some different spray tips for the PW, the coupler makes it super easy/fast to switch b/w tips/devices. Depending on the type of PW (electric vs gas w/ > 3200 psi) PW could have a lot of PSI built up in the line so a good idea to release the pressure before trying to remove the hose, foam cannon or spray tips to avoid injury. I have a couple of foam cannons for my PW & the QD couplers make it MUCH easier. Also have QD (Quick Disconnect) for all of my garden hoses/sprayers. Hope this helps
  18. #2698
    Feb 02 2017
    Beaverton, OR
    It needs to be a 1/4" Quick Connector that one is 3/8"
  19. #2699
    Mar 08 2013
    Southern Illinois
    Oops, thought I put it in there when I told him to take the PW gun to the store to ensure correct fitment but obviously not, sorry OP. Should have re-read B 4 I posted. Too busy watching the UFC pre-fight show
  20. #2700
    Mar 08 2013
    Southern Illinois
    Quote Originally Posted by DetailersDomain View Post
    email sent.
    Had to comment on a TV commercial I just saw for the Master Blaster on the Velocity Channel. Guess who is one of the featured spokesman, yep, our very own Phil. Congratulations Phil, just don’t go all Hollywood on us & forget the little people (just kidding). Nice to see an AZ sponsor getting national TV exposure & hope it continues, good for you!
  21. #2701
    Feb 23 2004
    how in the world did you see that? they cut me out of that video LOL
  22. #2702
    Mar 08 2013
    Southern Illinois
    It was an episode of Wheeler Dealers where they restored a Toyota Supra, near the last quarter of the show. You were prominently featured w/your printed names & business (Detailers Domain) briefly spoke of the uses in your business w/it & then they showed the guy from Chasing Classic Cars (Wayne ?) using/speaking ~ it as well, for ~ the same length of time.
    If they told U they were never going to use U in the commercial, they were incorrect & maybe owe U a small amount of $. I haven’t seen it before or since, but it was only yesterday so who knows if it will appear again, but if it does I’ll be sure to let U know. I was rather pleased for you to say the least!
  23. #2703
    Jan 30 2015
    SC
    Any good alternative to Einszett vinyl rubber? I tried the replacement by Nextzett but am not happy with the results.
  24. #2704
    Feb 23 2004
    strange it's the same formula, but that's cool what are you looking for primarily on the dressing? shine, gloss, matte finish, interior or exterior use?
  25. #2705
    Jan 30 2015
    SC
    I use it on the exterior, mostly on the tires. I prefer a matte look that lasts a decent bit.
  26. #2706
  27. #2707
    Veteran Member Three Rings doady22's Avatar
    Feb 28 2010
    ft collins colorado
    I just got a brand new set of wheels and want to ceramic coat them. Do I need to use and Iron remover and IPA still before applying the ceramic coating since they are brand new?
    2018 S5 Sportback, ECS Intake, Milltek HFC, Wagner Tuning IC, EPL E40 Stage 2, ABT HAS Springs, Vorsteiner Vff 107 20x10 ET30, Headlights by Oneighty NYC
  28. #2708
    Veteran Member Four Rings SleeperCar's Avatar
    Jan 03 2012
    VW Atlas and too many detailing supplies
    Wilmington NC
    Quote Originally Posted by doady22 View Post
    What ceramic coating are you going to use?
    2019 S4 Build
    2013 A4 Scuba Blue Metallic - SOLD (never forgotten)
    IG: @steves_s4
  29. #2709
    Feb 23 2004
    yes I would still use an ipa wipe down, you won't need an iron remover if the wheel is brand new in the box.
  30. #2710
    Junior Member Two Rings
    Feb 12 2018
    Dayton/OH
    Hello! I’m gathering up the supplies to jump into detailing my first black car. It’s a 2018 Audi A4 in Mythos black. I got it about 3 weeks ago but the car has been in service for 6 months (it’s a CPO). The paint is by no means in perfect condition and has micro swirls and small scratches here and there that are only visible under certain lighting conditions. I’ve done a ton of research and scoured various sites to decide and choose all the supplies that I will need but the more I read the more indecisive I get on what I really need (car detailing world has a TON of product options). So my thought was to do the following:
    - wash and clay and then wash again. I have Meguiars gold class shampoo from my previous car. Will this work or do I need something special as part of the paint correction process?
    - Polish with Meguiars M205 and porter cable orbital polisher. Now this is where i get a little lost. For the large areas I was thinking on getting a 5” backing plate and use it with 5.5” pads, but for the tighter areas like front bumper - use a 3” backing plate with 3” pads. In regards to the pads- what would you recommend to use with Meguiars m205? My research leads me to think that I need orange light cutting pads for the M205. Do I need to follow with Meguiars microfiber polishing pads or can I just wipe down with microfiber towels? If I’m completely off on the pads, please recommend the proper ones.
    - next step would be to apply a 50/50 diy solution of alcohol and water. Is this safe?
    - final step would be to apply a diy ceramic coating. I’ve read about the CarPro cquarz product as being decent... any other better diy ceramic products that you would recommend?
    That’s about it... I think :) am I missing any steps? Any product selection improvements I should make?
    Long shot - several days ago I got “sand blasted” by micro dust debris ( at least that’s what it felt like) on highway which caused tiny pin/needle size indentations on my front bumper ( not all over but in some areas). Although it’s not too terrible but still ticks me off that it happened. Would polishing with porter cable help alleviate those? Will ceramic coating help minimize these or do I need to hurry up and put up a clear bra? Thanks in advance!
  31. #2711
    Established Member Two Rings roush85's Avatar
    Apr 12 2012
    Bethesda MD
    Any spray on wheel protectant that works for brake dust?
    2016 S6 Prestige Tornado Grey. Stock for now
  32. #2712
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Quote Originally Posted by roush85 View Post
    Other than a coating?
    This: Sonax (04363000) Wheel Rim Shield - 13.5 fl. oz. https://www.amazon.com/dp/B01GS3EK3K?ref=yo_pop_ma_swf
    Sent from my Galaxy Note 8 using Tapatalk
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
  33. #2713
    Feb 23 2004
    Sonax Rim Shield can be used after each wash.
  34. #2714
    Veteran Member Three Rings WV_B8S4's Avatar
    Jun 11 2014
    Barboursville, WV
    Help!
    I picked up a 2014 RS5 this weekend, and a LOT of the car has XPEL or similar. The first problem is the edges of the film are looking pretty cruddy/gunked, and the second is there is a scratch in one of the pieces of film. These two issues make me want to remove the clear wrap and get the "canvas" cleaned up. The non-wrapped areas seem to have only minor swirl marks, I believe the car has been quite well taken care of so I don't think any major paint correction needs to be done.
    Historically, I've always kind of made up my own process from briefly watching videos and reading bottle instructions for wash/waxing my vehicles, and I've always been pretty happy with the results, but I've never taken the time to do it RIGHT.
    Trying to keep things to a reasonable cost without leaving anything out, I need an "essentials" list (assume I have nothing but a power washer and buckets) to show the paint some proper love: towels? sponges? soap? clay bar? polish? wax? seal?
    -Tyler
    Current Stable:
    2023 Starlight White F-150 Platinum
    2021 Bayside Blue Nissan GT-R
    Previous:
    Audis, Nissans, Mazdas, Chevy's, GMC's, Oh My!
  35. #2715
    Established Member Two Rings Swirv's Avatar
    Jun 09 2018
    2017 Audi S6
    CSRA, GA
    Any suggestions or experience on the correct process to follow when cleaning Audi Diamond stitched leather seats? I have lexol cleaner and conditioner along with a horse hair brush from Chemical Guys that I was going to use. Saw a few videos on cleaning leather seats, however I'm scared to mess up the stitched diamond pattern areas. Any advice is appreciated!
    2017 S6 | White Ext. | Arras Red Int. | S6 Sport Pkg. | Black Optics Pkg. | Driver's Assit. Pkg.
  36. #2716
    Feb 23 2004
    Quote Originally Posted by Swirv View Post
    we like to use the leather master kit to maintain these type of seats. the key is to use and apply product on applicators pads and towels first. massage the product into the pad so that it does not leave product on the stitching so much just enough where it doesnt get all over.
    - - - Updated - - -
    Update:
    Sonax Spray and Seal being used to maintain a ceramic coated vehicle.
    Using Sonax Spray and Seal for maintenance on a coated Lamborghini Huracan
    This Lamborghini Huracan was coated about 6 months ago with a ceramic coating, we wanted to test out the ability of the Sonax Spray and Seal and the effects of it over the coating. We are happy to report that it worked extremely well. Sonax Spray and Seal was compatible and showed no issues or side effects with the ceramic coating. We would recommend it as a maintenance product over your cars protected with ceramic coating.
  37. #2717
    Veteran Member Four Rings SDV325's Avatar
    Jan 20 2014
    Calgary, AB
    What are the top soaps to use on a ceramic coating? Recently has my car coated with CS-II Titanium SH and all my old soaps are not allowed (CG Honeydew, Wash/Waxes etc).
    Thinking CarPro Reset, Gyeon Bathe or Mequiars Hyper wash, thoughts on these or any other suggestions?
    2016 Audi SQ5 | Technik | Glacier White | Magma | Black Optics | Beaufort Inlays | Roc-Euro | Revivify Graphene Pro | EPL Stg 2 | Eurocode USS | MOOG Endlinks |
    2014 Audi SQ5 Estoril- STOLEN / RIP
    2015 Toyota Rav4 - Family Wagon
  38. #2718
    Feb 23 2004
    sure thing you can use
    Nanolex Pure Shampoo
    Fictech Ceramic Bubble
    Adam's Car Shampoo
    Lusso Auto Bath
    - - - Updated - - -
    LABOR DAY 15% off Site Wide (excludes Rupes Polishers)
    Starts Now - Ends 8/30/18 Midnight EST
    Use the PROMO CODE: LABOR (at checkout)
    Free Shipping on orders over $99.00 (this is based off the total after discounts)
    Click here to start shopping
    Phil Yiu
    Don't need anything check out our latest videos:
  39. #2719
    Sep 06 2017
    05 Subaru LGT (HTA71)
    MA
    A couple questions, attempting to keep my baby in top shape:
    The interior plastic trim pieces: I just noticed some scuffing / light scratches on my piano black interior trim in the bottom of the U shape of the trim around the center console (B8 A4/allroad center console). The shiny black between the cup holder and the MMI knob / buttons in picture 1. Is there a way to fill or smooth out the scuffing on plastic like that?
    My steering wheel: I have an all air-leather steering wheel (in picture 1). What is the best process to clean and maintain the wheel? Do I hit it with a leather cleaner first, then some sort of protectant?
    My wheels: I have what are supposed to be satin bronze Vossen VFS-2 wheels (picture 2). The brake dust situation is ridiculous and makes they basically gray. What supplies and method are best for cleaning the insane amount of brake dust that OEM brakes generate?
    Pic 1:
    Pic 2:
    > S4 Swapped B8 Avant <
    > 2015 Glacier White allroad P+ (RIP) <
  40. #2720
    Feb 02 2017
    Beaverton, OR
    Quote Originally Posted by Allthea View Post
    Akebono Pads for the brake dust issue - went from awful to wow they still look clean after a few weeks. Seriously do it. Cleaning the wheels with the OEM brake pads was tedious....now way quicker to clean.
    Steering wheel -
    Clean with Zymol Leather Cleaner
    Finish with Zymol Leather Conditioner
    Or
    Clean with Lexol Spray Leather Cleaner
    Finish up with Lexol Spray Leather Conditioner
    There are many other products as well.
