Page 4 of 70 FirstFirst ... 234561454 ... LastLast
Results 121 to 160 of 2784
  1. #121
    Stage 3 Forum Advertiser Four Rings DetailersDomain's Avatar
    Feb 23 2004
    Re: Ask Detailer's Domain
    I recommend if the wheels are new to coat use Swissvax cleaner fluid and swissvax autobahn.
    If they are not so new or need to be cleaned up use p21s wheel cleaner gel, followed by cleaning them up with a clay bar then doing the swissvax treatment.
    A good polish and sealant would work as well.
    Menzerna, Einszett polishes etc.
  2. #122
    Senior Member Three Rings Grenade's Avatar
    Aug 10 2005
    04 USP
    Las Vegas
    I've got a good one for ya Phil.
    I've got a Brilliant Black 04 USP, with some paint problems. I am not sure if it is water spots, or if it is actuall paint problems. No matter what I do, they are still there. They are very uniform, and are just on the hood only. I have tried a Few of the Meguire's Professional products, along with some buffing pads, diffrents ppi's and had a little luck. I've gotten the swirls to go away, but these spot are still here.
    I have a porter cable, 3 pads, yellow, green and black. And polishes/cleaner wax/swirl remover, and yellow wax.
    What products would you suggest hopefully to clean the paint, and then keep it glossy and protected? TIA
    USP CLUB MEMBER #686
  3. #123
    Feb 23 2004
    can you get me a good shot of the area.
  4. #124
    Feb 23 2004
    Lusso Glass Polish has been formulated to be safe for all types of tinted window films and is also safe for interior leather trim. The unique 360 degree fine mist sprayer will work when used upside down or sideways and will not leak or dribble on the dash.
    Lusso Glass Polish is a concentrate. Mix 4 to 1 with water for normal conditions, new cars or heavy smokers will benefit from a 2 to 1 ratio.
    and
    Lusso Auto Bathe® is based on a non-phosphate, pH balanced hair shampoo formula, without all the extras found in hair care products. The net result is a safe cleaner which loosens and removes dirt from your paint, but rinses off quickly and easily without leaving a finish dulling residue on your paint. Highly concentrated Auto Bathe will not strip the wax. You can actually feel the difference. Dirt is gone, wax remains, the shine is deep.
    I have to say I've been using both for sometime now and they are both amazing products.
    The Lusso Glass is great cause its safe on tint and the Auto bathe is super gentle and a great wash to upkeep your car, it won't strip waxes.
  5. #125
    Aug 10 2005
    04 USP
    Las Vegas
    Quote Originally Posted by phil@detailersdomain View Post
    I KNEW you were going to ask this. I will get a Hi-Res DSLR Pic for you when I get home. Thanks agian Phil.
  6. #126
    Aug 10 2005
    04 USP
    Las Vegas
    how's that work for ya? Its on an iphone, but ide like to hear your suggestions, because I want to put the order in today, so hopefully I could see it by the weekend, as my garage has become avaliable. thanks phil.
  7. #127
    Veteran Member Four Rings Elliott's Avatar
    Oct 28 2007
    Ocean Beach, CA
    I've a question. I know that white cars are not inherently show-stopping. But when I wash/wax/clay/polish etc my white B6 it just does not look as awesome as it seems like it should. Is there anything I can do to give the white some BLING?
    CEO and General Manager of the AZ Pedal Responce Team
  8. #128
    Feb 23 2004
    are you doing it in that order?
  9. #129
    Oct 28 2007
    Ocean Beach, CA
    Sorry, wash/clay/wax/polish is what I meant. Is this the right sequence?
  10. #130
    Feb 23 2004
    1. wash
    2. clay
    3. polish
    4. wax.
    watch these videos:
    http://www.detailersdomain.com/index...on=Custom&ID=3
  11. #131
    Nov 13 2007
    '07 A3 2.0T
    Tampa, FL
    working on another order (I think I am addicted to supplies!) and no longer see the Adam's In & Out Spray listed, I really like the results from it, will you be getting it back in stock or is it gone forever? Anything else you recommend that would give similar results?
  12. #132
    Feb 23 2004
    jetta,
    unfortunately in and out is on a break till they revise some components for VOC Compliant.
    for now engine covers I do that with black wow and trim I like using Swissvax Pneu with a tire sponge on rubber bits, the hard to reach areas will still be hard to reach though.
  13. #133
    Nov 13 2007
    '07 A3 2.0T
    Tampa, FL
    ahh that makes sense (used it in the garage once, that was fun ) Guess I will give black wow a try, thanks
  14. #134
    Jun 05 2008
    '08 A4 2.0T SE
    jersey
    i see you're recommending Swissvax cleaner fluid and swissvax autobahn for new wheels. are these the best available products for cleaning/polishing wheels.
    have you come across any other reliable polishers/sealants
  15. #135
    Feb 23 2004
    there are other reliable products out there.
    you can also use Einszett Glanz.
  16. #136
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    still looking at how to get the shine back in this knob:
    (not a pic of my actual shift knob)
    It's the OEM knob for a 25quattro S4. It's lost it's shine around the numbering and lettering. How can I safely polish this without ruining it? I don't even know what it's made of.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
  17. #137
    Feb 23 2004
    you can try on of the metal polishes we carry.
  18. #138
  19. #139
    May 31 2007
    Montreal
    Phil.. maybe I missed it.. but I couldn't find any 1Z cockpit premium.
    Please let me know if it's b/o.
    thanks
  20. #140
    Feb 23 2004
    cockpit should be back in stock in 7-10 days.
  21. #141
    Senior Member Three Rings zbrock06's Avatar
    Oct 15 2006
    '04 USP A4 1.8TQ
    Stamford, CT
    i'm going to be ordering the adam's PC essentials kit, and i'm wondering what i should use to get the scratches out of my door? they are light scratches like something rubbed up against it, and you can't see them unless the sun hits it just right. Will i need a compound or just the revive that's included in the kit?
    USP CLUB MEMBER #94
  22. #142
    Feb 23 2004
    Quote Originally Posted by zbrock06 View Post
    you can use the swirl and haze the revive polish
    watch these videos:
    http://www.detailersdomain.com/index...on=Custom&ID=4
  23. #143
    Registered Member Two Rings
    May 28 2007
    Bogota
    Hey PhIL quick question... What do you consider the best interior cleaning products such as carpet cleaner/interior /leather ?
  24. #144
    Feb 23 2004
    best interior cleaner/protectant - Einszett Cockpit
    Best leather care: Leather Master strong cleaner/Vital conditioner/Protectant
    Carpet cleaner would be Adam's Carpet and Upholstery.
    The link:
    interior care at Detailer's Domain
  25. #145
  26. #146
  27. #147
    May 28 2007
    Bogota
    Thanks alot phil
  28. #148
    Feb 23 2004
    sure thing
  29. #149
    May 31 2007
    Montreal
    Phil
    I'll be placing an order soon, today or Monday. 1 question for you.
    I'm interested on using the swissvax autobahn. Most of my clients have asked for a wax than can protect their wheels and make it easier to remove brake dust.
    when polishing a wheel I'll clean with P21S wheel cleaner, P21S polishing soap, and then the sealant/wax. Do I still need the Swissvax cleaner fluid ?
    TIA
  30. #150
    Active Member Two Rings 06sline's Avatar
    Mar 27 2008
    06 a4 sline VW Golf Trek
    Jersey
    Phil or any one else,
    I plan on getting some Menzerna SIP. My question is can I get away with using Adam's Revive Polish as a follow up or would I need to use PO85RD or could I even use the Menzerna Micro Polish?
    Thanks
  31. #151
    Feb 23 2004
    Quote Originally Posted by 3.0 Rider View Post
    Phil
    TIA
    p21s polishing soap should be used on non clear coated surfaces. on surfaces that are clear you can use the cleaner fluid then the autobahn.
    so this is how we do it.
    wash the wheels with p21s, then clay them, then cleaner fluid, then autobahn.
  32. #152
    Feb 23 2004
    Quote Originally Posted by 06sline View Post
    Thanks
    I would say get the 85rd or the mircopolish my vote though will be for PO85rd.
  33. #153
    Mar 27 2008
    Jersey
    Thanks Phil
  34. #154
    Feb 23 2004
    no problem
  35. #155
    May 31 2007
    Montreal
    Thansk again Phil
    How long does the wax lasts?
    And is this the best wheel wax you ever tried?
  36. #156
    Feb 23 2004
    I like this wheel wax alot it does last a long time but remember you have to stay on top of it just like the others.
    I would have to say on any wheel wax though if you decide to hit it with a wheel cleaner to clean the brake dust off you will probably remove some if not all the wax.
    when you do have a wheel wax on the car I would wash the wheels more frequently with your car wash then put another coat on maybe after every other wash.
  37. #157
    May 31 2007
    Montreal
    Thanks again Phil.
    just before I placed my ordered.. I forgot I'll be running out of FMJ.
    But what about the 106FA. I still have an unopened bottle of 106FF but I'm curious about this one.
    What are the differences? and if I get it, how long will the unopened 106FF bottle can last in a cool tempered area.
    Thanks again.
  38. #158
    Feb 23 2004
    Menzerna has no shelf life. But use the 106ff if you have it.
  39. #159
    Feb 23 2004
  40. #160
    Feb 23 2004
    We now give you the customer the ability to build your own kit with some of the best proven products out there.
    The best part is that you save a nice amount of money on some of the best products out there.
    You can put get 10 pads, plus Menzerna polishes and Swissvax or you can get a base kit with pads, accessories, mf towels, Einszett, and so on.
    Click here to build your Flex XC3401VR, we give you the freedom to choose what you want.
    If you don't see it or have any other suggestions please e-mail me.
    We will be adding the same options for the Makita, Metabo, PC, and the Flex Rotaries.
