Results 1 to 13 of 13
    May 13 2004
    Irvine
    Real Post...Audio Experts
    i been lookin at the eclipse audio AVN2454 monitor and I was wondering If i can just install that monitor with nav to the factory bose speakers and bose amp...I dont want to change any speakers or amps...Is this possible?
    Veteran Member Four Rings hyperspeed's Avatar
    Feb 13 2004
    Chino Hills, CA
    yeah thats fine u can power everything off the head unit
    Feb 23 2004
    Audi A4 1.8T
    Los Angeles CA
    dont think so and heres why
    bose runs ****ed up superlow impedances so your head unit amp will probably overheat. can be fixed with new speakers and bypassing rear amp.
    Veteran Member Four Rings BoostTed's Avatar
    LA
    if the B6 bose is anyhting like the B5 bose than the front speakers bose or non-bose are powered off the headunit...these are the normal 4ohms and can be powered by the headunit. Its the rear that will cause you a problem, a solution is to convert the rear wire into RCA's and connect them to the headunits pre-out.
    Feb 23 2004
    Audi A4 1.8T
    Los Angeles CA
    the rears and sub are powered by the amp, and the front is powered by the head unit you are correct.
    Veteran Member Four Rings gohan's Avatar
    PA
    will it work for non-bose? i'm getting mixed answers from Audiworld
    2010 B8 Avant - Aired Out - Gone
    2003 B6 Sedan - Gone..
    Feb 23 2004
    Audi A4 1.8T
    Los Angeles CA
    yes it will work fine with non-bose. if you are adding a sub you might want to disable the stock sub too
    Feb 13 2004
    Chino Hills, CA
    oh u have bose. nevermind not too sure then..
    santa monica CA
    bose sucks...that is all :)
    Feb 17 2004
    Liberty Hill, TX
    on the B6 w/Bose, all speakers are powered from the amp in right side of the trunk. The head unit simply feeds the amp with line-level signals. Whether they come from the stock HU or an aftermarket one shouldn't make a difference. The inpedence of the speakers doesn't matter to the HU as it's passing everything to the amp, not connected directly to the speakers
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Feb 22 2004
    San Diego
    the bose system can be run no problem by an aftermarket head unit. there is an adapter that connects the 2 no problem. the only thing i noticed when i first did that was that the speakers didn't sound quite as good as when the bose headunit was running them. solution: focal seperates in all four doors and a new sub. much better now!
    Feb 26 2004
    Akron, OH
    LMAO, basically a whole new system...
    Feb 23 2004
    Audi A4 1.8T
    Los Angeles CA
    u sure?! first off i thought the bose amp only powered the rears and sub like boosted stated. secondly that means he must splice rcas somewhere in the stock amp and run those to the head unit.
    if he has low impedance speakers he cant run it off the headunit which runs at 4 ohms. i think bose impedance is what 1/2ohm or less? 20 watts @ 4ohms = 160 watts @ 1/2 ohm = bye bye head unit amp.
