Guys please help.
I picked up a K04 kit recently and was testing out the chip, but the car won't start and the check light does not show while the key is in the ignition.
During the process, I also removed the entire chip and board off the main PC board of the ECU. I can plug it back in in either direction and it will fit.
My question does it matter which direction it goes in because I can't tell which position was the original position. ALso will it mess anthing up if I plug it in the wrong way backwards/forwards.
Please help. If I do this right and the car still does not want to start, what does that mean? Messed up board or messed up chip? BTW, I also have a stock program socketed chip that I've plugged in that works on the ECU so I know it is not ECU that is faulty.
