Hey all,
Here is the STaSIS special for August;
1. STaSIS Street Sport coilover kits are again on special; $945 and a free STaSIS crew shirt in the color of your choice.
Numerous kits for Audi(and VW) are available;
-STaSIS Street Sport Koni Coilover Kit for B6 A4 1.8T/3.0 Quattro and FWD; 4 KONI sport dampers; single adjustable (rebound), narrow band; suspension disassembly required for adjustment; cadmium plated threaded steel damper bodies; height adjustable; 4 progressive rate KONI springs (450/440 spring rate); balanced and adjusted on SPA damper dynamometer
-STaSIS Street Sport Koni Coilover Kit for B5 A4/S4; 4 KONI sport dampers; single adjustable (rebound), narrow band; suspension disassembly required for adjustment; cadmium plated threaded steel damper bodies; height adjustable; 4 progressive rate KONI springs (400 lb. spring rate); balanced and adjusted on SPA damper dynamometer
-STaSIS Street Sport Koni Coilover Kit for B5 A4/Passat FWD; 4 KONI sport dampers; single adjustable (rebound), narrow band; suspension disassembly required for adjustment; cadmium plated threaded steel damper bodies; height adjustable; 4 progressive rate KONI springs (400 lb. spring rate); balanced and adjusted on SPA damper dynamometer
To put any misconceptions aside, these kits are off-the-shelf Koni coilover kits that have been further modified by STaSIS. STaSIS puts the dampers on their shock dyno, matches the set of 4, sets the rebound damping for optimum ride/handling, and also sets the spring perch heights. This results in a fantastic ride and great handling. You'd be hard pressed to find conventional dampers and springs for this price and even if so, you wouldn't have the flexibility of ride height adjustability and rebound damping to set the vehicle where you prefer.
2. As well, any other STaSIS suspension, brake, or drivetrain items are available at a 5% discount.
Keep in mind that by purchasing through us in Oregon you save on sales tax which can save you a lot of $$!! Couple that with our expert technical knowledge/product support and exceptional customer service and you won't find a better company to deal with in the entire industry.
As always, let me know if you have any questions either by PM or email. I am always here to help.
Best regards,
Jeremy
