    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2017 B9 A4 Quattro/DSG/Technik/S-Line... 2004 B6 A4 1.8T Quattro race car
    Montreal, Canada.
    N 75-K valve update...
    Switched back to my stock OEM N 75 valve. Using the K version produced several "overboost" situations and the ECU went in to limp mode.
    Veteran Member Four Rings hyperspeed's Avatar
    Feb 13 2004
    Chino Hills, CA
    yeah those results were registered by other people testing the N75 K valve also. sorry to hear. but at least you were boosting pretty dam high!
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    too bad, but with the right tuning, you won't even need it.
    Veteran Member Three Rings pkancel's Avatar
    Apr 10 2004
    2020 BMW M340i, 2019 BMW 330i, 2015 BMW 328i
    Mission Viejo, CA
    Jet Jokey, how much have you done to your car. I only have a Neuspeed Chip, plugs and filter, so wondering if this simple setup might be better for those sleeves. Have you done more where the boost is higher already and the sleeves just put it over the edge?
    2017 BMW 540i / 2015 BMW 435iGC / 2017 Audi A3 Quattro
    Jun 17 2004
    Montreal, Canada.
    I think you are confused with another Mike. I do not use sleeves. I tested a different version of the N 75 valve, the K version.
    In my set up with my regular OEM N 75 valve the boost peaked at 22 to 23 psi and stayed there for a while. It gradually droped to around 15 psi.
    With the K version we saw peaks of 29.9 psi with the boost staying near 25 psi and slowly droping to around 20 psi.
    This caused several "overboost" situations and the ECU went into limp mode. I decided that it is not worth the trouble at this time to risk any damage to my turbo. Until I speak to MTM in Germany the OEM N 75 will stay in the car.
