Results 1 to 11 of 11
    Registered Member Three Rings AFOUR_PLAY's Avatar
    Apr 15 2004
    Sydney, Australia
    Injector and FPR
    What injectors and fpr are you running and with what engine mods?
    Is the 364cc injector with 3 bar FPR too big for a KO4 kit?
    Is the 310cc big enough with 3 bar fpr?
    Daniel
    http://smileys.smileycentral.com/cat/3/3_2_116.gif
    A4 1.8T Quattro - Clicky Here
    -Stoptech Brake lines - RS4 Grille - DIESELGEEK SS - GFB DV - APR Snub Mount - K04 Turbo - Samco Turbo Inlet Hose - S3 injectors - GIAC - 18x8.5 1/16 Carlsson copy 18/40/235
    Feb 23 2004
    audi, vw, 72 bronco
    ne, pa
    364 seems a little big but 310 is a little small. 330 would be an optimal number i think. prob. 310 w/ 4 bar would be good. see if anybody else has an opinoin. turbo90 are you there.
    Veteran Member Four Rings Burntaudi's Avatar
    Sold:1997 Audi A4
    Maplewood, Minnesota
    I'm running that setup K04 with larger injectors. Basically the software was dyno tuned for Bosch "red tops" 310cc injectors W/3 bar FPR. I think if you run anything bigger with a K04 and software your just gonna burn rich and actually lose power. You may wanna talk to www.dynospotracing.com since GIAC originally did the tuning on their dyno for this setup.
    By the way I burned rich with my setup originally but I think that was because of the outdated MAF...seems fine now with the newer MAF.
    By the way there's 2 different software files for the AEB motor with K04 /larger injectors.
    PGK16 which seems to run a fair amout of boost or
    PC16 which runs less boost but a really aggressive timing curve and requires a FMIC.
    Alex
    Sold 97 Audi A4 Turbo Quattro Manual
    KO4/GIAC PC-16/GHL Exhaust/EVO FMIC/ Southbend Clutch/JHM Short Shifter & Linkage/Shifter Bushing/Koni Coilovers/Neuspeed Sways/17" OZ Superellegras/Ecode Headlights/VVME Hids
    Current ride 03 Tahoe Z71
    Apr 15 2004
    Sydney, Australia
    Do you need to have the specific software to run bigger injectors or will the same chip for 5 bra FPR run it ok?
    I ask this because my I have the AJL engine code and don't think there is a program for the bigger injectors.
    Daniel
    Sold:1997 Audi A4
    Never heard of the AJL engine code what year is that. I know the rest of the world got different engine codes that we never saw in the states. That being said you need the correct software to run larger injectors W/FPR
    Unless you have a tuner that has the correct software for larger injectors your probably better off sticking with the standard K04 software made for your engine code.
    Alex
    Apr 15 2004
    Sydney, Australia
    AJL is the 180Hp engine, I'm from Australia.
    This engine was released in 1999.5 to 2001
    We never got the 170Hp engine in the B5 shape.
    The stock injectors wont have a problem with 5 bar fpr?
    Daniel
    Sold:1997 Audi A4
    I would think that stock injectors would be fine with a 5 bar. Is there a local tuner that has K04 software for your car.
    Alex
    Feb 13 2004
    <> Posts: 9913
    So what exactly is different in the 180hp engine? I'm guessing it's the same motor, but maybe they run higher boost? Or maybe different emissions regulations? I'm curious.
    -Theodore Roosevelt, 1907
    Apr 15 2004
    Sydney, Australia
    I have the KO3 sport and i've been told that the wiring and ecu is different to the 150hp my car also makes 10psi with 12psi spikes standard.
    I do have an Oettinger dealer near by and Wetterauer dealer.
    APR don't make software for me.
    Daniel
    Sold:1997 Audi A4
    I would hitup both of those dealers and see what they have to offer...i'm pretty sure both of them offer K04 programs. If no one makes K04 software for your car it's not gonna be woth it to upgrade.
    Alex
    Apr 15 2004
    Sydney, Australia
    I know they do offer the K04, both offer 230Hp 265 torque with 5 bar fpr.
    Daniel
