Results 1 to 8 of 8
    Registered Member Two Rings
    May 12 2004
    Grinding/Rattling sound
    My car makes a weird grinding/rattling sound. It's sound kind of like sticking a playing card in a fan or bycicle wheel. It happens in every gear at really low rpms(around 1200-1600) and only lasts for a split second. It also happens during start-up and sometimes happens during idle. My car is a 1.8TQ, stock chip.
    Veteran Member Four Rings DRA4's Avatar
    Feb 12 2004
    B5 S4
    Check your timing belt.
    Giac stage 1 279whp-327wtq
    TEAM A.C.E. NY
    Me: Siri where do lesbians hang out?
    Siri : I found 2 Subaru dealers fairly close to you
    May 12 2004
    What should I be looking for. Is it common for the timing belt to be causing these sounds.
    Veteran Member Three Rings G-low's Avatar
    Feb 13 2004
    Ct
    i also get a little rattle/vibration noise for a split second but it seems to happen when i hit boost but still at low rpms was wondering what it was it sounds like something metal is vibrating agains something any ideas??
    97 1.8tqm T3T4
    May 12 2004
    I read alot of people had this problem but nobody said anything about resolving it.
    Feb 13 2004
    <> Posts: 9913
    It could be a lot things. Rattles/Vibrations can come from pretty much anything, like a loose heat shield. Other rattles often come from the cat, either it's going, or has a crack in it, etc... It could also be the throwout bearing.
    There's just too many possibilities. You'd need to be much more specific as to where the sound is exactly coming from.
    -Theodore Roosevelt, 1907
    Feb 17 2004
    Sterling, VA
    I had a strange clicking noise coming from my belts right after I bought my car. It was a rythymic ticking sound from the belts/pulleys area.
    When I replaced my timing belt, I found that the waterpump belt was the culprit. It was very dry-rotted and would make a squeaking noise as it rolled over the pulleys. The squeak was so quick and low-pitched that it sounded like a click.
    The A/C belt can also become stretched out and make a dragging sound when the belt is cold.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Feb 13 2004
    Ct
    i wish i could find out where the noise is coming from but it only happens when i hit boost so i cant exactly get out and listen, y buddie was in the car with me and he was telling me that his clutch makes a noise like that sometimes so maybe its the hrowout bearing
    97 1.8tqm T3T4
