Results 1 to 12 of 12
    Mar 05 2004
    PA
    Replacing valve cover gasket-what else should I do?
    This sunday I am replacing the valve cover gasket and fuel filter. What else would be a good thing to replace while I'm in those areas?
    '98.5 1.8
    Q7, Q7, F-type manual
    Why are you replacing the gasket, an oil leak? Chances are high that its not the gasket and is the cam tensioner seal. This is a much more involved job (cam removal is required). If you get it replaced, there are also some other seals on the cam that should get done. Take it to a mechanic and see if he can tell you where it is leaking. Valve cover gaskets arent cheap, and cant be reused, so it would suck if it didnt solve your problem.
    Feb 23 2004
    audi, vw, 72 bronco
    ne, pa
    fuel filter by the tank. be sure to tell us how that goes. hear it is a real pain.
    Feb 13 2004
    <> Posts: 9913
    I did my fuel filter. Not too bad, and it was badly needed.
    There's a great write-up on AW.
    -Theodore Roosevelt, 1907
    Feb 23 2004
    audi, vw, 72 bronco
    ne, pa
    i want to do it, i will have to check the how to on a.w.
    Mar 05 2004
    PA
    Gasket cost me 33 bills. I'd say that is pretty cheap for being a genuine Audi part.
    I didn't even think about the cam seals. I guess I'll have a look Sunday when I do the VC gasket. It never hurts to replace stuff, so I may as well do it.
    Mar 05 2004
    PA
    As far as the fuel filter. I have all the tools I'll ever need, plus a choice of 5 different types of lifts so I should have a problem...at least they aren't in the tank. :)
    Sigless...
    Veteran Member Four Rings RedRocket's Avatar
    Feb 12 2004
    Toronto GTA
    Valve cover gaskets are very cheap and very easy to change. Did you mix up your gaskets ?
    Feb 12 2004
    Toronto GTA
    The writeup on AW for the Fuel Filter is good. You will need the 12 pt. Tq key (if that's what it called). Also ensure you charge the system(Key ON) and check for leaks three times(ON/OFF) for about 5 seconds each time before actually cranking.
    Apr 21 2004
    2013 S4 6MT, 2011 Escalade
    Coopersburg, PA
    When I took my car in for its last oil change, I was given back an estimate saying that my valve cover gaskets, camshaft tensioner and camshaft tensioner seals would all have to be replaced. It actually turned out to be the upper and lower oil pan seals. (I know, what the heck is an upper oil pan seal?) If you are having a leak, this might be another area to check out.
    2013 S4 6MT // sport diff // B&O // Phantom Black // Black Leather and Black Alcantara
    maybee it a cool 2.8 thing, sorry guys . I dont remember mine being cheap, and there were 2 of them. but you are right, they are easy to change.
    Feb 12 2004
    Toronto GTA
    Oh ya, I didn't see that you had the "Bigger" engine. lol
