Results 1 to 4 of 4
    Registered Member Two Rings koolAsiCE's Avatar
    Feb 26 2004
    Alfa Romeo 147, Audi A4 1.9TDi Quattro
    England, London
    Flywheel and Clutch
    Hi,
    I'm after a good reasonably priced flywheel and clutch set.
    It's for a 1997 Audi 1.9TDi Quattro sport.
    I am not after a race kit, just for your everyday driving.
    Please could the UK members answer this one.
    Feb 17 2004
    Sterling, VA
    If you drive this car everyday, stay with the OEM dual-mass flywheel. The lightweight flywheels for the A4 are noisy and ruin low rpm torque.
    As far as clutches go:
    If you're always going to keep the stock turbo, get a stock clutch
    If you're going to get a larger turbo than the OEM one, the following brands are decent:
    Spec
    Southbend
    Werks of Art
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Veteran Member Four Rings Devious27t's Avatar
    Mar 02 2004
    2001.5 S4 Avant on Corn
    Orange County
    Spec
    Southbend
    Werks of Art
    not everyone has problems with their flywheels. i have a 12lb and everything is perfectly fine. my problem right now is getting used to my 4100 lb pressure plate.
    as far as clutches go i would recommend south bend or the company formerly known as werks of art.
    Feb 17 2004
    Sterling, VA
    You are the first person I've heard from that doesn't have a ticking car after installing a LWFW. I'm not sure why but, maybe the step height on your FW is different from most of the other ones out there.
    There's a very large number of people on here and AW who have had this same problem with various clutches, it always turns out that the LWFW was the common part that each person installed.
    I spoke to 2 diffrerent guys over at New Dimensions and they both explained that the Spec clutches have some issues of their own but, the ticking noise is specifically from the LWFW.
    Apparently, the way that the FW interacts with the clutch disc when engaged, causes it to chatter. The friggin' guys at Spec told me it was only a temporary thing that would go away with break-in. I've got 1200+ miles on it now and its the same, if not louder.
    Brett - Moderator
    Issue?: email me.
