Results 1 to 6 of 6
    May 06 2004
    W124s
    PA
    Can I use higher wattage bulbs?? Need answer fast...
    I already have HID low beams in my DOT spec projectors, love it. works wonders. Now I need something to help overcome the lows so I can actually see further. I already have wiring harnesses in place, 12awg wiring for the highs and 14 for the HID lows, fused 40a relays. So I am set on the wiring end, no headlight switch replacement ever again(I pray). What I really need to know is can the stock one peice housings hold up to continued heat from high wattage bulbs??? How high can I go? I am considering some 100w bastards, that ought to do, huh? looking for output, not colors.............
    looking for info soon so I can order some better bulbs asap....
    Account Terminated Four Rings MR VTEC's Avatar
    98.5 Audi 1.8TQM
    Brooklyn
    my high beams ddnt sty on when i had my hid installed i had to flip the stalk the other way that was when one of my ballasts went out.
    Veteran Member Four Rings skene's Avatar
    Feb 13 2004
    Las Vegas
    55w.... leave it at that... any higher you are looking at cooking your wires in the long run.
    2017 Toyota 86
    Feb 10 2004
    2009 A4 2.0T Sedan
    Well they're for your brights it sounds like, so they won't be on all the time. I personally wouldn't go any higher than 70 or 80 watts.
    May 06 2004
    W124s
    PA
    As I stated in my original post, I have upgraded the wiring enough that I don't have to worry about any cooked wires. I could run 155w bulbs if I wanted too.... Not that they make them in H7 or that I would buy them if they did. All that I am concerned with is will I risk damaging the reflectors or the lenses or any part of the head light housings, anything besides the wiring.
    I think Anthony might be right, 100w may be a little too much heat for as long as I use the high beams some times.....
    Veteran Member Four Rings RedRocket's Avatar
    Feb 12 2004
    Toronto GTA
    Re: Can I use higher wattage bulbs?? Need answer fast...
    I can't answer this for you but I have 3 halogen headlamps that I can send ya if you do f-up your current ones
